Question about Insignia 22 in. Widescreen Flat-Panel LCD HDTV
I can't get the cable to come in clearly and I've tried all of the inputs. It is hooked up to a cable box and I just recently had a different tv hooked up to it and it worked so I know its not a problem with the cable and I know I hooked it up right. I also tried getting it without the cable box and that was all fuzzy too. How can I fix this or program it to get the cable coming in clearly?
    Problem Solver:
  • 17 Answers
If the cable direct to the tv is bad you probably have a low signal strength problem such as too many or poor quility splitters being used. It's only a 22" so take over to a friends house and see if the problem goes away.
Good luck
Rich
Posted on Jun 07, 2010
Tv wont get channel signal
1- Have you tried a different input cable?
2- maybe try using the set top box tuner?
3- check the input setting on TV?
Good luck
Dec 11, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Why does my Sony STR-K750P AV receiver automatically switch to Video 2?
Some models of systems will switch to a new source automatically if the source sees a new signal coming on. Try disconnecting the device on your Video 2 to see if this is the case.
I have seen the IC or component(s) in the switching circuits become defective and cause unpredictable or faulty operation. This can also be a fault condition you are seeing.
Apr 02, 2017 | Sony Str-k750p Av Reveiver
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
HOOKING TV UP TO CABLE DIRECT TV MITSUBISHI VS 412 R
Check tv is set to pal or ntsc....it has to be the same as the output if the box.Then check the connections...have you a different hdmi lead as sometimes the lead is the wrong class....also try a different output slot or input slot to tv....change the av input or tv menu....do not use the tv to tune the box...you need to set the tv to the right av input for the box...then use the box menu to tune the box.....finally if the picture is still snowy then it has to be the dish alignment...or the cable between the dish and box connections is not tight enough.
Jan 11, 2018 | Televison & Video
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Insignia 22 in. Widescreen Flat-Panel LCD HDTV Logo
69 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
