Question about Kitchen Ranges
Kitchen aid oven is running to hot after running self cleaning cycle a few days ago.
  • Kitchen Ranges Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Jun 07, 2010
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Kitchen Aid KGRA806PSS
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Lg electric range oven touchpad buttons not working
Did they stop working after running the self-cleaning cycle? That is what happened to mine. I moved the oven and unplugged it. Left it unplugged for a few days waiting for repairman. He plugged it in when he got there, and everything worked. He advised against using the self-cleaning cycle because the heat can cause problems with the touchpad buttons.
Jul 04, 2014 | LG LRE30451 Electric Kitchen Range
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    I need my kitchen aid oven to unlock
    NEVER use the self cleaning feature - again!!
    Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
    KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
    Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
    Jan 27, 2011 | Whirlpool GS460 Gas Kitchen Range
    We have a kitchen aid KGSA906PSS00 gas range. for the first time today the wife decided to run the self clean function. At some point through the self clean the oven shut off and the control panel died....
    Jan 27, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
    The oven door cannot open. The self cleaning cycle was not completed because the display window went blank and as a result the oven door remained locked. This occured during the Christmas season and...
    Jan 24, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
    Describe how to access the self cleaning feature on the accubake oven and how long does it take?
    Press the "Auto Clean" or "Precise Clean" button depending on the control type of your range. Then press start. The oven should lock and start the self-cleaning cycle. The cycle is usually 3 hours from start to finish and cannot be stopped once it has started heating. The range gets extremely hot and causes the inside of the oven to act like a catalyst to burn the grease. It will create smoke and odor depending on how dirty the inside of the oven is. Make sure to leave the exhaust fan on above the range to remove some of the heat. And definently do not do the cleaning cycle on a hot summer day!
    Feb 19, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
    PUT THE OVEN ON SELF CLEAN AND IT DIED
    the operating feature i that it will not let you open untill the oven has either fineshed cleaning or the oven has cooled off
    Oct 29, 2009 | KitchenAid KESC307 Electric Kitchen Range
    Self cleaning
    Sometimes, according to what I've seen.  My theory is that the elements are probably covered in grime and this causes the damage.  As far as the control...I don't think that makes sense.
    Never use cleaner on the elements..also causes damage.
    A typical duty cycle for cleaning is 2- 2.5 hours.  Longer and you could burn them up, too.
    Nov 28, 2008 | KitchenAid KEBC101 Electric Single Oven
    Kitchen Ranges Logo
    59 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
