Question about Dell 962 Photo All-In-One InkJet Printer
Cartridge error1203 - Dell 962 Photo All-In-One InkJet Printer
  • Dell Master
  • 4,737 Answers
Sometimes Covering up a copper contact on the cartridge helps.To do this,use a small tape or apply small amount of Liquid eraser on the contact point of the cartridge, 2nd row of the contact point (2nd from the left). The error will be cleared and the cartridge will work. If your cartridge is new, i would suggest you to get a replacement instead of doing this. Good luck Thanks for using FixYa.
Posted on Jun 06, 2010
Error1203
Clean the contacts where the ink cartride snaps in.
Feb 17, 2011 | Dell Photo 926 All-in-One Printer
Error1203 what it means
Hello thanks for using Fixya
The error 1203 is a cartridge error. It
is an issue that occurs either when a cartridge is bad or the printer cartridge slot is bad
To solve it try this. This solution works
  • Try cleaning the copper contacts of the both carts and cart slot in the printer and try again OR
  • When error shows up, Turn the printer to Power Off. Wait one minute and turn it back on.
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 28, 2011 | Lexmark X4250 All-In-One InkJet Printer
My printer will not accept the ink cartridges I have bought because they are not from lexmark it is showing error1203 how do I get around this?
Possible that the ink cartridges are not meshing along with the contacts. Hence the original is important to get the ink cartridges to contact.
Remove and set back the cartridges, if possible remove the printer and reinstall after removing the driver software. If this wont work the original cartridge must be sourced.
Dec 08, 2010 | Lexmark X5470 All-In-One InkJet Printer
I have a lexmark 2580, I keep getting 'unsupported cartridge' message, and one of the lights on the printer is constantly blinking. I have brand new lexmark cartidges installed.
Problem Unsupported Cartridge; Error: "Unsupported cartridge"; Incompatible cartridge error; Incompatible cartridge in the printer; Cartridge not recognized Solution What you will see
When a cartridge is inserted, an Unsupported Cartridge error message is displayed on the printer operator panel.
Affected printers
This issue affects printers sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. NOTE: The cartridges for these printers are sold exclusively in these stores or on their websites.
Explanation
The printers listed in the table below are compatible with a #2 cartridge (in single cartridge printers) or a combination of #2 and #3 cartridges (in two-cartridge printers). They do not support the standard color 28A 35, and Mono 29A 34 ink cartridges. If the standard color 28A 35 or Mono 29A 34 ink cartridges are used in these printers, they will fail to print and the printer will post an Unsupported Cartridge error message.
Solution
Lexmark recommends using either a #2 cartridge for single-cartridge printers or a combination of #2 and #3 cartridges in two-cartridge printers.
Cartridge compatibility chart
NOTE: These printers are sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. The cartridges for these printers are sold exclusively in these stores or on their websites.
Item Printer #2 Color Cartridge #3 Mono Cartridge #31 Photo Cartridge 1 Lexmark Z738 Yes ... ... 2 Lexmark Z1380 Yes Yes Yes 3 Lexmark Z1480 Yes Yes ... 4 Lexmark X2480 Yes ... ... 5 Lexmark X2580 Yes Yes Yes 6 Lexmark X3480 Yes ... ... 7 Lexmark X3580 Yes Yes Yes 8 Lexmark X4580 Yes Yes Yes
Nov 07, 2010 | Office Equipment & Supplies
How do you open for ink replacement?
Removing an empty print cartridges Follow the steps below to remove an empty print cartridge:
  1. Press the Access Cartridge button on the control panel. The cartridge carrier moves to the remove/install position. Figure 1: HP Fax 1040/1050 control panelc00253378.gif 1 - Access Cartridge button
  2. Open the control panel and cartridge compartment cover (it will click and remain open). Figure 2: Opening the control panel and the compartment coverc00253379.gif 1 - Control panel 2 - Cartridge compartment cover
  3. Pull the cartridge toward you until it releases from the print cartridge cradle and then remove it. Figure 3: Removing an empty print cartridgec00253380.gif 1 - Pull cartridge towards you 2 - Remove cartridge from print cartridge cradle
Installing a new print cartridge Follow the steps below to install a print cartridge.
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape using the pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: HP 20 print cartridgec00259017.gif
  2. With the cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place. Figure 5: Inserting a new print cartridgec00253382.gif 1 - Insert the print cartridge into the print cartridge cradle 2 - Push the top of the cartridge until it clicks into place NOTE: If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
  3. Close the cartridge compartment cover and control panel.
  4. Press the Start/Enter button.
  5. On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old. NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
for more information follow the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00253364&tmp_task=useCategory&lc=en&dlc=en&cc=ca&lang=en&product=425911
Jun 18, 2010 | HP 1040 Plain Paper Inkjet Fax
I get the error message: error1203 when I start my printer what can I do to solve this problem?
This is an ink cartridge problem. Go to the following site and see if it helps. I don't know which printer you have so you'll have to look at the site and pick out your model. Good luck! http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&productCode=&segment=SUPPORT&question=error+1203#1
Mar 13, 2010 | Office Equipment & Supplies
Replacing Ink Cartridges
http://www.lexmark.com/publications/pdfs/2007/6200/winug/en/frameset.html
Note: Make sure the All-In-One is on.
  1. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position. sscano.jpg
  2. Press down on the cartridge lever to raise the cartridge lid. scrtrpc1.jpg
  3. Remove the old cartridge. Dispose of empty ink cartridges (see Recycling Lexmark products). Use the cartridge storage unit that came with your photo cartridge to store partially used cartridges for future use. See Using the cartridge storage area. scrtrpc2.jpg
Note: If you are removing both cartridges, repeat steps 2 and 3 for the second cartridge.
Installing the print cartridges Note: If you are installing a photo print cartridge, remove it from the print cartridge storage unit. Place the empty print cartridge storage unit in the cartridge storage area. For help, see Using the cartridge storage area.
  1. If you are installing new cartridges, remove the sticker and transparent tape from the back and bottom of the cartridges. staperem.jpg
Warning: Do not touch the copper contact area on the back or the metal nozzles on the bottom of the cartridges.
  1. Unless they are already open, press down on the cartridge levers to raise the cartridge lids. sctnin2.jpg
  2. Insert the black cartridge or the photo cartridge in the left carrier. Insert the color cartridge in the right carrier. sctnin3.jpg
Note: The control panel display will prompt you to print an alignment page.
Note: The scanner unit must be closed to start a new scan, print, copy, or fax job
Feb 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
What is error 1203?
Hi, there is quite a long troubleshoot for this problem and so hopefully if you follow this link you may be able to solve it.
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:463:0:0&docid=ENUS25242
See how you go.
Oct 26, 2007 | Lexmark X7170 All-In-One InkJet Printer
Error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Aug 20, 2007 | Lexmark P315 InkJet Photo Printer
Dell 962 Photo All-In-One InkJet Printer Logo
113 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
