Question about Coby DVD765 Theater System
Coby dvd765, how to connect that system /speakers to Panasonic TC-P65s1. I have my coby dvd player connected to my tv. I have it connected via component 1 - Y-Pb-Pr-L-R. I also have it connected to back of the dvd player as such. I have a opitcal connected to tv and dvd player. I want to use those speakes from the dvd765 for my tv as well instead of using it for dvd. please advise.
3 Suggested Answers
  • 133 Answers
SOURCE: I am looking for the region free code to unlock
1. Open DVD Tray
2. Press the “Menu” button
3. Press 8888
4. Press the “Display” button
5. Region Code Number shows up. Use the numeric keypad to select your region
code number (0 – 6).
6. Press the “Setup” button to exit.
Posted on May 03, 2010
  • 133 Answers
SOURCE: Can't control TV volume after installing Coby
Unfortunately that is how this unit is designed, you cannot adjust the volume while inputting from an external source, normally the subwoofer would have an AUDIO control, but this one has no knobs, the VOL +/ VOL- on DVD remote only controls while watching a DVD. Only work around for this is if your TV has a 3.5MM headphone jack, you can get a 3.5mm to RCA cable and then your television would be able to control the volume.
Posted on Jun 04, 2010
Need a manual coby dvd765 theater system
I run into this problem quite a bit.
According to the Coby web site, there is no 765.
The closest thing to it is the 755.
Coby DVD 755 Manuals Support and Troubleshooting Home Theater Systems
When you go to sites like this, dont click on the giant "DOWNLOAD" buttons as they are always advertisements.
My Retrevo My Manuals This is a direct link to the manual so you dont have to click a dozen links till you hit the right one.
Good luck.
Jan 13, 2014 | Coby DVD765 Theater System
I have the coby 765, when i switch the buton to tv it is very loud even with the tv and dvd player turned completely down
Unfortunately the subwoofer should have a volume control knob, and the subwoofer for the DVD765 does not have this, that is why it is so loud, the only work around is to get an audio cable with a built in volume control knob.
Oct 27, 2012 | Coby DVD765 Theater System
I am not able to hear the dialog while playing DVDs. The background is great and comes through all 5 speakers, however, to be able to listen to the dialog, I have to switch over to 2-channel or Stereo. ...
Well let me first ask is the center chanel working? or properly hooked up. Cause most of the times when in 5.1 the talking or "dialog" as you put it comes only through the center channel its just kinda how they do it. Listen to see if the center channel is working. if you are unsure try hooking up a speaker that you know works into the center channel speaker output. If no sound comes out then the reciever possible has blown its center channel. Please follow up with a comment and i will be glad to assist you further thanks, Midwes-tek
Sep 17, 2010 | Coby DVD765 Theater System
I have a Sylvania sst4324s tv and would like external speakers. The owners manual says the red & white audio output jacks are 2W 8ohms ea. Do I need an amplifier with speakers to make these work or...
At 2 watts, it would run very small speakers without an amp, but I suspect you would be more happy with a home theater amp. There are a number of surprisingly inexpensive models with DVD players in the same unit. Here is an example:
http://www.overstock.com/Electronics/Coby-DVD765-Home-Theater-System/3981690/product.html
Hopes this helps:)
Aug 23, 2010 | Sylvania SST4322 32" TV
Coby DVD765 Theater System and can't control the TV volume through it...I saw the previous post...We have it in our bedroom and rarely watch DVDs in there. Could I plug my RCA audio cables into some of...
The connections will have to go directly into your tv set. On your tv, you should have 3 connnecting points. Red, White and Yellow. On your Theatre system amplifier you should have audio outputs like CD, AUX, etc. Pick one of these outputs and connect to your Red and White RCA on the tv set. Next, connect the DVD player's audio to dvd on your amplifier under the DVD connection. Your VIDEO (yellow) Cable should still go to your tv directly from the DVD player. Now, if you want to listen to the TV channels throug the system, simply select the channel that you pluged the TV audio into. Hope this helps.
Jun 11, 2010 | Coby DVD765 Theater System
Can't control TV volume after installing Coby DVD765
May 04, 2010 | Coby DVD765 Theater System
I am looking for the region free code to unlock the Coby DVD765 player I have just bought. Any ideas please?
1. Open DVD Tray
3. Press 8888
May 01, 2010 | Coby DVD765 Theater System
I CAN NOT GET ALL 5 SPEAKERS TO WORK
I know this is not the answer that you want to hear, but: That television is not capable of delivering audio output to all 5 speakers - it is a stereo-only TV, which only delivers 2 channels.
Furthermore, that Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
The manual for the Coby mentions a "Digital Decoder Amplifier," which would work. You would connect a digital audio cable from the area marked "Coaxial" on the back of the Coby to a digital audio IN on the back of an external amplifier. You would connect the speakers to this amplifier, instead of directly to the back of the Coby. Then you would need a cable or satellite box with digital audio outs (fairly common nowadays) to another digital audio IN on the back of the amplifier. The cable or sat box you may have already, but you may need to purchase such a "Digital Decoder Amplifier" or other digital amplifier with appropriate speaker wires and 2 digital audio input slots (not to mention two digital audio cables). Fairly complex. Possibly expensive.
-Tha Mp3 Doctor
Feb 20, 2009 | Coby DVD-937 5.1 Channel DVD...
Question: how do you connect to a cable box?
That Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
-Tha Mp3 Doctor
Jan 31, 2009 | Coby DVD-937 5.1 Channel DVD...
Coby DVD765 Theater System Logo
277 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
