Question about Canon I900D InkJet Photo Printer
My cannon i900D will not print anything
My canon i900D was working perfectly, then in the middle of a picture the rest of the page came out blank, since then it will not print anything, the paper goes through all the printing motions but comes out just as white as it was when it went in, there is not a smudge of ink on the paper. i,ve done noddle check, deep head cleaning, print head alignment,ect,got nothing but blank paper! no warning, waste tank full, or anything, it obeys all commands, and says its printing, but all i get is white paper! help!
3 Suggested Answers
ksdi
  • 34 Answers
SOURCE: smudged text
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
286
Posted on Mar 16, 2009
MUKHTAR
  • 2022 Answers
SOURCE: i900d waste ink tank getting full
· 1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press
RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
or try this
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
I hope this info helps you.
Posted on Sep 15, 2009
Cannon ir2022n printing blank page how to solve problem
Normally, the machine is set by a specific IP address initially. People run connect the machine though other internet connection in that case print shows blank page.
Just connect your machine with the IP address you did initially. And then try to print.
Otherwise,
Click the following link for online support
https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/support-multifunction/imagerunner-2022
Jun 08, 2017 | Cannon Office Equipment & Supplies
Cannon LBP 2900 lazer printer cartridge is refilled. than it prints blank page only.
canon 2900 printer first time refilling completed but print not coming wht is problem
Sep 12, 2012 | Canon LASER SHOT LBP-2900 Printer
My I900D Canon printer Prints But the paper is blank.I have tried printing from pc and testing only with the printer still blank paper. Can you help me?
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is connected to the PC and reconnect it back.
And change the cartridge (Place a new cartridge instead of the old one)
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer automatically now.
Now you will be able to print.
Oct 17, 2011 | Canon I900D InkJet Photo Printer
Color not printing correctly on canon i900d
Take the cartridges and print head out. Pour about a centimeter of boiling water into a saucer or shallow bowl and set the print head in it for about 30 seconds. Place it on a folded up paper kitchen towel for a minute to dry and replace print head and cartridges in printer. Run two normal cleaning cycles and a nozzle check. If the test print is still poor or has not improved at all, the print head is probably dying and it is time to find a new machine. If the print has improved but not perfect, just repeat the process a couple of times.
Dec 11, 2017 | Canon I900D InkJet Photo Printer
Improper color on Canon i900D printer with Vista OS
It's the drivers. On the Cannon website there are no drivers listed for this printer with Vista.
Apr 04, 2009 | Canon I900D InkJet Photo Printer
Skin tones in pictures coming out ''sunburned'' looking
please verify with other image(pic) from elsewhere.....than that of your source..just to verify that its the printer itself......print a pic from web....
Nov 14, 2008 | Canon I900D InkJet Photo Printer
I900D cannon printer
I was having the same problem and I put the printer through the head cleaning and auto head check and it now seems to be working fine.
Aug 28, 2008 | Canon I900D InkJet Photo Printer
I have a canon i900d I can't install the driver in xp
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Dec 08, 2007 | Canon I900D InkJet Photo Printer
Photo printing
It is definite one cartridge is not running. You do one thing - 1. Write documents in MS-Word - select all - change the color to Red. Take print out. Check Printing is perfect or not.
2. Write documents in MS-Word - select all - change the color to Cyan. Take print out. Check Printing is perfect or not.
3. Write documents in MS-Word - select all - change the color to Yellow. Take print out. Check Printing is perfect or not.
I am sure when you changed the color to Cyan - it did not print Cyan or blank page you got.
So you must replace the Cyan cartridge or may be ink is not coming out through the passage. And first you have to check whether you have removed the plastic tape from the head of t he cartridge.
Oct 25, 2006 | Canon I900D InkJet Photo Printer
Canon I900D InkJet Photo Printer Logo
165 people viewed this question
old marine
old marine
