Question about Porter Cable 6,500 Watt Contractor Portable Generator #H650IS W
My generator runs but doesnt put out to the electrical outlets
    Scholar:
  • 130 Answers
You may have to check the wiring, With the engine off check the following: they may be a loose wire, the brushes on the generator may be too worn. Check for continuity from the outlet all the way to the generator.
Posted on Jun 06, 2010
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Oct 14, 2014 | Electrical Supplies
Tip
Generator runs great but produces no power
On Thursday last week I had 220 amp outlet being used and a 110 amp outlet being and overloaded the generator. It turned out to be the reset breakers failed to trip and blew the capacitor. The reset breakers I would suggest replacement after 7 years very easy to do on a 5500 Valsi generator 2010 model still running and now producing electric. And of course use only regular gas non Ethanol.
on Aug 19, 2015 | Electrical Supplies
Gentron gg3502d outlets have no power
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
May 24, 2014 | Gentron 10,000W Generator with Electric...
Geberator runs put no power on the outlets
I had the exact same problem. All i did was take off the fuel tank, take off the heat plate take off the the plug that goes to the outlets then i took off the cover to the brushes to the solenoid i cleaned it with sand paper very lightly, i wiped it down with electrical cleaner, i put it back together and it worked perfect. i usually dont do this but if i can be of any help feel free to call me at (432)235-0026 if i dont answer please leave a voicemail i will call you back nut i hope this was help enough.
Jul 30, 2012 | Husky 3650 Watt Generator with Subaru...
Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine No AC output
Sounds like the generator unit (sometimes called the generator head) has overheated and melted the insulation in the windings. This is the same as an electric motor "burning out", and if this is the case, then the generator is toast. If you happened to notice that the lights or fans were getting dim or slowing down before the breaker tripped (without the gas engine slowing down) then this is most likely the case and you generator is toast. But if the output just suddenly quit, then it is possible that some smaller electrical component has failed. In any case, it's not something external that you can easily reset or replace. Sorry for the bad news.
Jun 13, 2012 | Porter Cable BSI550 W 5,500 Watt Generator...
I have a coleman 6000. It runs for a whileand when I load it up it trips off.
Make sure the governor is working properly. When you put a load on it the engine should increase in speed slightly. Make sure the engine is running at the correct speed 3600 rpm. Try plugging in an item that draws less power such as a electric drill and see how the generator behaves. Also make sure the engine runs smooth while not under any load. Check the voltage from the outlet to make sure it is putting out 132 volts not under load.
Mar 14, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
Mitsubishi MGE 6700 generator. Starts and runs fine, but no longer putting out power. What would it cost to repair this issue?
These generators have a GFI outlet on them, and they do fail. I would suggest you check all output circuits and see if you have any output. If so, pull the GFI and see if it is getting power to the outlet. If so, replace the outlet.
Feb 20, 2011 | NEC Mitsubishi MGE 4000 Generator ROU...
No electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Jun 09, 2009 | Porter Cable Electrical Supplies
Coleman 5KW gen motor shuts down when A/C switch turned on
Sounds like a problem with the wiring of the outlets after the circuit breaksr. Take apart the outlet box and have a look for burned or broken wires, melted outlets, and/or small critters stuck in the wiring.
I recently had to repair a generator that had its voltage regulator taken out by a frog!
Regards,
Carl
Feb 28, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Jan 16, 2009 | Coleman Powermate Premium Plus 6250W...
Porter Cable 6,500 Watt Contractor Portable Generator #H650IS W Logo
450 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
