Question about Inverter Welding Tools
I have a cheap chinese plasmam cutter a giant cut
I have a cheap chinese inverta plasma cutter ,a giant cut 40. When i press the trigger the red O.D light comes on and i have no spark. Air is coming through fine.
  • 25 Answers
Internal componet failure, return the machine for repair. Who did you purchase it from?
Posted on Oct 21, 2010
I have cheep chinese plasma cutter cut 50 comes on and does spark got air it will not cut what could be problem
HF spark gap adjustment needs to be done, it's inside the machine, front of bottom circuit board.
Dec 03, 2014 | Welding Tools
Spectrum thunder plasma cutter will not cut steady, keeps stopping and have to pull trigger to cut
Check the contactor contacts for pitting. if severly pitted, replace contactor. If a death grip on the switch makes it work better then a light touch- replace the trigger switch.
Aug 17, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
Pilot arc is highely spreaded
change the cutting nozzle
Mar 23, 2012 | Hobart Welding Tools
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma cutter only cuts for only a few seconds
The unit needs to be tested.
You're welcome to ship the unit to me for diagnostic testing and repair. info@taeckertindustries.com
Nov 07, 2009 | Airforce Welding Tools
Lotos cut 40 plasma cutter, not firing
Test all the mosfets, good chance one or more are failed.
Jul 28, 2009 | A & A Manufacturing Ramsond 40D Plasma...
No Arc on a Cut 40 Plasma cutter
Check your consumbales to be sure they are tight in the torch head. Check your ground be sure it's good and connected to the pc you are cutting. Make sure you are running air at 65 to 70 psi as it exits the torch. Email me if you have any other questions.
Jul 14, 2009 | A & A Manufacturing Ramsond 40D Plasma...
Miller plasma cutter stops cuttingafter a few seconds
the cutter probably has a built in current monitor. that trips out then resets itself. try a lower current.
Mar 24, 2009 | Welding Tools
Welding Tools Logo
546 people viewed this question
Top Inverter Welding Tools Experts
Tom Chichester
Are you an Inverter Welding Tool Expert? Answer questions, earn points and help others
