Question about Refrigerators
I agrre with the responce, i have purchsed the replacement parts, which include the delivery door for the ice dispencer, but i would like to know if you would havw some step by step insrtuctions on how to remove and replace these parts
    President:
  • 1,561 Answers
Unplug the refrigerator from the electrical outlet, and carefully pull it away from the wall. Turn off the water supply at the wall. There is a plastic water line attached to the refrigerator and the main water line. Pull this tube off the refrigerator.
Unplug the refrigerator, and turn off the water supply at the wall. Find the valve, which is located on the outside of the refrigerator door or in it. There is a plastic cover over the valve that is held in place by screws. Unscrew the cover, exposing the valve. Take a digital photo of the valve so you can use the photo as a reference for installing the replacement.
Disconnect the valve from the refrigerator and the water line. Install the replacement valve, referring to the digital photo. Plug the refrigerator back into the electrical outlet, and turn on the water supply.
Take care.
Posted on Jun 06, 2010
  • singh2715 Jun 06, 2010
    its not hte water valve, its the dispensing unit for the ice cubes, where the ice cubes are delivered into your water glass.
  • Sulaimon Jimoh Olayemi Jun 06, 2010
    Follow the link below to see the user manual and how to connect the parts of your dispenser unit
    http://www.iceomatic.com/docs/uploaded/i...
    Type the above link in your web browser and follow the information therein.
    Take care.
The ice dispencer keeps backing up and I can't get the ice bucket to come off the freezer door. Help please!!!
must be a whirlpool / or ka . open the door and let it thaw then remove it and de ice it with hot water . dry ir good and the ice delivery shoot .. spray the dry surfaces wth food grade silcone and this will helt for a while . do this about every 3 mo to prevent this prob . mm
Oct 13, 2010 | Maytag MZD2766GES Side by Side...
Ice despencer opening keeps freezing and wont dispence
you have a bad door seal. replacement is better than repair. warm moist air is getting in and the condensation is freezing.
Nov 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
What is the part called (the little flap that closes after Ice comes throught the dispencer?
it's called an "ice chute door". Look on sears.com, select "Parts Direct", another page will come up, enter your model number of your frig, then enter, wait a few then your model info will pop up, select either the freezer door or if it has "Ice & Water dispencer" select it, wait for another page to come up, then look thru diagram for part you are looking for, then scroll down to that part number and you will be able to see actual mfg part number. There should be a "Ice Chute Repair Kit" listed as that is how they come. Search internet for best price.
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
