Question about Solis Master 5000 Espresso Machine
Brewed coffee goong into used grounds holder
Alot (about 1 ;3) of the coffee is going into the grounds tray instead of the cup. I just cleaned the machine and the circular filter with the tool. Did I replace it wrong? Is there a trick to it?
  • 1,089 Answers
HI
That is a stripped thumbscrew. You need a new one. When it starts to brew, the stripped thumbscrew pushes up and allows the coffee to fill the head and dredge drawer.
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. It holds the filter screen in place. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Posted on Jun 07, 2010
Testimonial: "nailed it! Now I just need a new thumbscrew"
My coffee machine is dumping coffee into tray every now and then
You need a new drainage valve,while you change that you might as well change the orings on the brew group
Nov 24, 2014 | Jura Ena Micro 1 Automatic Coffee Center
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
Keurig drips too slow
The exit needle is located on the inside bottom of the K-Cup Holder. If coffee grounds or cocoa mix gets clogged in the exit needle, it can be cleaned using a paper clip or similar tool. Remove the funnel from the K-Cup Holder, insert the paper clip into the tube and move it around to loosen the clog and remove any debris. Please note, you cannot poke all the way through the needle as the opening of the needle is located on the side and not the top.After cleaning, align the K-Cup Holder tabs with the opening placing the two front tabs on the bottom and the single tab on top and snap it into place by pushing down on the top rim.
Aug 28, 2013 | Keurig K-Cup Keurig OfficePRO Single-Cup...
Kerig Vue will not come out of the preheat mode
This worked for me: 1) Turn off machine 2) Remove lower tray. It pulls right out. make sure it is clean. RE-insert. 3) Remove upper tray. It's a little trickier, put it also pulls down and out. Mine was full of coffee grounds. I rinsed it out with tap water. 4) Replace upper tray. 5) Take a used V-cup and take the foil and filter out leaving only the plastic tray. Clean it thoroughly of coffee grounds with water. Replace it in the V-cup insert. 6) Power on the Vue. It should come on pretty quick and say " Ready to Brew" run 6 to 8 oz through with just the blank V-cup. This will clean out any remaining debris. 7) Now put in a new V-cup and brew your coffee!
Oct 04, 2012 | Keurig Vue Brewing System
Our cuisinart kcup coffee maker is leaking out the top of the machine. When it brews instead of a stream coming out of the pour spout, the machine leaks water all over the main brewing piece (where the k...
Take out the used kcup and GENTLY explore the holder fitting. There should be a sharp point in the bottom that punctures the bottom of the kcup to allow the brew to flow out the spigot and into your cup. There also needs to be a sharp point on the top to punch a vent hole for the water to enter. It they aren't both open, coffee and grounds will spray everywhere. Take it apart and clean thoroughly as well.
Nov 02, 2017 | Cuisinart Keurig B50 Single Cup Coffee...
We bought a Kurig Mini at this past Christmas. The machine worked great for about 4 months then the Kcups started exploding in the machine and coffee grounds would go into the brewed cup. Then the...
Mine has been doing the same thing.  I alkso received one at Chriustmas and it worked great for a few months.  Below is the answer I received from Keurig:
It is possible that the needle that penetrates the K-Cup has become clogged.  Please follow these simple steps to clean it:
Turn off the brewer and unplug it.
Reach under the nozzle (where the coffee comes out) and press up on the bottom of the funnel.  The K-Cup holder will pop out.
Separate the K-Cup holder into two pieces.  The top piece of the K-Cup holder is where the exit needle is located.
Use a paper clip to clear the exit needle by putting the paper clip in the tube on the underside of the holder. Be careful, the exit needle is sharp.
Wash the K-Cup holder with soap and water, rinse thoroughly.  Also make sure the drawer is clean.
Put K-Cup holder back into the drawer, making sure it snaps into place.
Plug the brewer in and turn on.
Run two cleansing brews (brew without a K-Cup) through the machine, and then brew a cup of coffee.
If you still find grinds in your coffee, it would be best for you to talk to a representative to help troubleshoot your problem and discuss your options.  This could be caused by too much pressure sealed inside the K-Cup or the filter alignment may be off.  Please contact our customer service department at 1-866-901-BREW (2739).  Representatives are available 7 days a week from 7 a.m. – 12:00 Midnight EST to assist you.  Please have the serial number of your brewer available for when you call.
The serial number for the Mini is located on the bottom of the brewer on a silver sticker.
For the Classic, Ultimate and Select, is located on a sticker behind the drip tray.
For the Elite, Ultra, Special Edition and Platinum it may be located either on the bottom of the brewer on a white sticker or, behind the drip tray.
Sincerely,
Briana Keene
Keurig Customer Service
At Home Division
(866) 901-BREW (2739)
csrah@keurig.com
Aug 25, 2010 | Keurig B30 Mini Coffee Maker
My machine only brews 1/2 cup of coffee. I have de-scaled twice within the last week and I get a full cup of vinegar/water, but as soon as I put in a K-cup I only get 1/2 cup of coffee out. The first cup...
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Aug 15, 2009 | Keurig B60 Coffee Maker
My Keurig B60, 1 month old is not brewing enough coffee
Check the needle inside the k-cup holder to ensure it isn't clogged. You can completely remove the k-cup holder and rinse it out using your kitchen sprayer to help loosen any debris stuck inside the needle. The needle is what punctures the k-cup and extracts the coffee from within the cup and can become clogged. Make sure when you replace the k-cup holder, that you align the arrows and snap the top or arrow-side in first. If simply rinsing your k-cup holder and needle don't do the trick, try inserting the end of a small paper clip into the needle to push out any remaining debris. This technique is actually recommended by the manufacturer, so it won't void any warranty or damage the needle. After replacing the k-cup holder back into the machine, try brewing a cup of coffee to see if it did the trick.
As a side-note, if you regularly use any "Hot Cocoa" k-cups, you need to make sure and immediately brew a cup of just hot water (no k-cup) to help clean it out and prevent the needles from clogging. The Hot Cocoa k-cups are notorious for clogging the needles up thus causing the problem you described above.
Hope that helps...best of luck!
Apr 11, 2009 | Keurig Special Edition B60 Coffee Maker
Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Apr 06, 2009 | Keurig B50 Coffee Maker
Amount of coffee to use
This is from the FAQ section of West Bend's website at www.focuselectrics.com:
As a guideline, use the following amounts of ground coffee for the number of cups being prepared. Use standard measuring cups ( as used to measure flour, sugar, etc.) to measure the coffee. The amounts of coffee below will brew mild to medium strength coffee which most people prefer. The amount of coffee can be adjusted to suit personal preference. As a guide, there are about 5 cups of coffee to a pound (16 ounces).
  • 12 - 18 Cups Coffee = 1 - 1 1/4 Cups Grounds
  • 20 - 25 Cups Coffee = 1 1/4 - 1 1/2 Cups Grounds
  • 28 - 36 Cups Coffee = 1 1/2 - 2 Cups Grounds
  • 40 - 45 Cups Coffee = 2 - 2 1/2 Cups Grounds
  • 50 - 60 Cups Coffee = 3 - 4 Cups Grounds
  • 70 - 80 Cups Coffee = 4 1/2 - 5 Cups Grounds
  • 90 - 100 Cups Coffee = 5 1/2 - 6 1/4 Cups Grounds
  • Hope this helps. You might also be able to download the manual from there if you look for your model.
    Sep 23, 2008 | West Bend 13500 Coffee Maker
    Solis Master 5000 Espresso Machine Logo
    181 people viewed this question
    Top Solis Coffee Makers & Espresso Machines Experts
    graybeard32301
    Colin Stickland
    Colin Stickland
    AZBen
    AZBen
    Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
