Question about GE JES1142SJ Microwave Oven
Cuts off when gets too hot
When i bake potatoes for 4 or more monutes it gets too hot and cuts off and won't come back on. i have to store microwave for weeks un plug and sometimes it will start to work after that.the microwave is new just over 1 yr old.
    President:
  • 2,702 Answers
Inside your microwave is a heat censor, if it cuts the microwave off then its to hot for safty have a good look round the back of it to check that the air vents are all clear and that a good air supply can get all around it when its cooking food,,, iv seen so many microwaves tucked away into a small place, and they will all cut out when they get to hot,,,1100 watts gets very hot too!
Posted on Jun 06, 2010
I just bought a new rice cooker container for my family to cook rice. It saids use one cup of rice with 1 and a half of water and microwave for ten minutes. Then thought I use 3 cup of rice then must...
you do not need to triple the time when tripling the quantities, example: one baked potato = 8 min, 2 = 10 min,3= 12 min ....
sounds like a triple batch is a bit much for your microwave
so you may want to cut it in half
Feb 09, 2015 | Microwave Ovens
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
I have an Electrolux High Speed Oven E30SO75FPS that's 3 years old and the Magnetron has failed for the 3rd time. What can be causing this?
Is the internal cooling fan working?
Are the ducts and vents clear?
Problems with any of those can result in overheating, which destroys magnetrons.
I have seen high voltage rectifier diodes interact with magnetron in funny ways. I'd replace the diode, too.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Finally, baking potatoes and making popcorn really give the magnetron a workout.
You should put about 1/2 cup of water in the rear corner of the microwave when cooking those foods.
It helps "preload" the oven to prevent execessive microwave energy reflection back to the magnetron.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Dec 12, 2011 | Microwave Ovens
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
I was cooking 4 potatoes for 14 minutes then put in frozen corn, started the microwave oven again and everything shut down.is there an internal fuse or breaker? or is it time for a new one.
Many of these ovens have either a humidity sensor or oven cavity sensor that will shut the oven down if the internal oven cavity humidity or temperature exceed a certain level. Baked potatoes are often a culprit as they retain a good amount of heat and generate humidity when they cook. In most cases, allowing the oven to cool down with the door open for about half an hour will restore operation.
However, there is also a thermal cut-out (TCO) on some models that will trip if the internal temperature of the oven cavity gets too hot. If the TCO trips, it must be replaced.
Since you posted no Brand Name of Model Number, I do not know how your oven is configured. If you post back with this information, I can verify and may be able to diagnose a cause of your problem.
Sep 16, 2009 | Microwave Ovens
Preheated oven with glass dish...tried to bake..now no power
they have a fuse that blows if the cavity gets to hot looks like a small thermostat
Jun 30, 2009 | GE Advantium SCA1001SS Convection /...
I used the sharp to bake potatoes and after two
Assuming that the internal cooling fan was working properly, it may be as simple as a failed magnetron thermal cutout.
I don't have an exploded view on this one, and the supplier's part list is not detailed properly, so you would have to remove the magnetron thermal cutout and look for the numbers on it, either 145 or 150.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Then here would be the part numbers:
RTHM-A080WRE0 Thermal Cut Out 145 Degree c
RTHM-A085WRE0 Thermal Cut-out 150'C
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
You should also check the 20A ceramic fuse. Fuses can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
If you need more help, please replay back. Otherwise...
Jun 22, 2009 | Sharp R-7A95 Microwave Oven
GE JES1142SJ Microwave Oven Logo
243 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
