Question about Printronix Line Matrix P5005B Printer
"Table Mismatch download to continue" erroe on display"
We had service printer and cleaned ram/dram slots but still this meaasge apperas after diagnosys passed in the display
  • Anonymous Feb 11, 2009
    table mismatch please download
    Problem Solver:
  • 6 Answers
Pl. chack your board wether it is CFX or CMX ,download the firmware accordingly.
upadhyay
Posted on May 12, 2008
Reseat ribbon cable and power cable on hammerbank
Posted on May 31, 2008
How to clear bizhub 163v memory
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings ?< ? ,< ? Quick Settings ? < ? >
3. The SERVICE MODE menu screen will appear.
11.10.2 RAM TEST
A. Use
• Write or read data to/from RAM memory to make sure of normal operation.
• When test finishes and everything is okay, it will display "RAM CHIP IS OK" and automatically clear DRAM.
After DRAM clear finish, LCD will display "DRAM IS CLEAR!."
B. Procedure
• Pressing the Menu/Select key will start the check.
• After approx. 30 seconds, "RAM CHIP IS OK" will appear.
Does not work have a tech come out
May 16, 2016 | Konica Minolta bizhub Office Equipment &...
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
Can I increase the RAM from 504 to 1008 on my D310m/845G?
Yes you can increase the RAM of your motherboard. It contains two DIMM slots, but can only be upgraded to a maximum of 2-GB ( max of 1GB on each slot.) The slots support DDR Synch Dram PC2100 (266-MHz) and DDR Synch Dram PC1600 (200-MHz) Non-ECC Memory only.
Nov 02, 2010 | Compaq Evo D310M 845G P4 Motherboard
How many slots for dram chipsets? For AZ11/ AZ31 motherboard? Thanks!
FIC AZ11 (First International Computer {Inc}
3 Ram Memory slots.
Supports SDR Sdram at 100MegaHertz, or 133MHz. (PC100, and PC133 respectively)
Maximum Total Amount is 1.5GB
Maximum Amount for EACH ram memory slot is 512MB. (1/2GB.)
Uses the VIA KT133 motherboard chipset,
(Northbridge - VIA VT8363
Southbridge - VIA VT82C686A/B)
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
Socket A processor socket for AMD processors. (Also referred to as Socket 462)
http://www.xbitlabs.com/articles/mainboards/display/fic-az11.html#
FIC AZ31
3 Ram Memory slots
Same type of ram memory as above, same total amount, and amount for each ram memory slot.
Uses the VIA KT133A motherboard chipset.
(Northbridge - VT8363A
Southbridge - VT82C686B
Socket A processor socket.
http://en.wikipedia.org/wiki/Socket_A
http://www.baber.com/baber/411/fic_az31.htm
Oct 30, 2010 | FIC AZ 11E Motherboard
What does erroe code 2 mean?
paper jam , but you ned to open the upper cover then clean stel ruller which the head of ink cartdrige move in it when it copy then but graze and then clean the slot of unite waste ink yiu see it when the cartdrige stop move then put graze on it and try move it on you hand some times and see the move must be very easy thts all
Dec 18, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
About my ram of p4m800-m7 rev 3.1 i have a 512mb ram already installed and i buy a new ram with a 1gb size and i would like to install it but my question is is it okay to put them together? my 512mb ram is...
The black rectangular chips on the side, or sides, of the ram module are DRAM chips. Dynamic Random Access Memory.
('Chip' is slang term to denote IC, or Integrated Circuit)
Each Dram chip is of a specific size, (or can be said as Amount)
There are manufacturers who make the Dram chips, and then the chips are used by the ram memory manufacturer.
Doesn't matter how the Dram chips are arranged. The ram memory manufacturer could put them all of one side, if they designed it that way.
1.Your motherboard will support, (Use), DDR at 333Mhz, or DDR at 400MegaHertz.
(PC2700 and PC3200, respectively)
2.The ram memory module must use 2.5 Volts.
(JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts, so no worries here. Only time to check this, is if you have some High performance ram, that may be set to use a higher voltage)
3.It must be Non-ECC ram, and Unbuffered.
4.Cas Latency should be 2.5 to 3.0 (Ram Timings)
Short solution?
Computer off, and unplugged from power. TOUCH the metal frame of the computer case to relieve your body of Static.
Handle the ram 'sticks' by the body of the stick, and refrain from touching the gold plated contact pins, on the bottom.
If the 512MB stick is in SLOT 1, remove it. Install the 1GB stick in Slot 1. Make SURE it is seated!
(Slot 1, is the ram memory slot that is closest to the Processor. It is the first ram memory slot that the Processor reads)
Leave the computer case open. (Refrain from putting your hands in while the computer is plugged into power)
Plug the computer into power. Wait 30 seconds. Turn the computer on.
Computer boots up? (Starts)
Okay.
Unplug from power. Install the 512MB stick in Slot 2.
Plug into power, wait 30 seconds. Turn the computer on.
Computer boots up?
You're good to go.
1GB ram memory stick is in Slot 1, and the computer does not boot up?
Incompatible ram memory. Remove it. Reinstall the original 512MB stick in Slot 1.
Nov 26, 2009 | EliteGroup P4M800-M7 Motherboard
Fargo printer display DRAM MEMORY BAD
the memory module will need to be replaced on that unit, I believe on that unit it is replaceable. I have worked on these before. we are an authorize service center forit.
Jan 10, 2009 | Fargo Pro L ID Thermal Printer
Flash a printer
I can email you the Flash Program.
If a “Table Mismatch” is displayed, recycle power and reflash the printer. Can get “Table Mismatch” after replacing CMX Board.
“Table Mismatch”
Flash Upgrade Instructions Using the printer’s Parallel Port: Have Ethernet? You can FTP download.
1. Print a configuration on the printer prior to the download. After the flash is upgraded, the printer will be at Factory settings and you will need this printout to restore any non- default settings.
2. The PTX flash code is on a CD you should have received with printer. Don’t have? I can email you the Flash program.
3. Turn the printer's power off.
4. If there is a cable connected to the printer’s serial port, disconnect it.
5. Connect a cable from the LPT1 port on a PC that has a DOS prompt mode to the printer’s parallel port.
6. While holding down the Online & FF(Paper Advance) keys, power up the printer. The printer will display "Waiting for Program Download".
7. At the PC’s DOS prompt, go to the directory where the file is located C:\Temp and
type "filename.exe -pb<ENTER>" where filename is the name of the file that you downloaded in step 2.
NOTE: there is a space before the -pb
8. The printer's display will keep you informed of the status of the download. When the download is complete, cycle the printer’s power.
Dec 01, 2008 | Printronix Line Matrix P5215 Printer
Table Mismatch Download Again
This is the only Solution to "Table Mismatch"...
“Table Mismatch”
Flash Upgrade Instructions Using the printer’s Parallel Port: You have ethernet, you can FTP download.
May 15, 2008 | Printronix Line Matrix P5215 Printer
Table Mismatch Download Again (Printronix P5215)
hi
i have an error " tabel mismatch download again" on my printonix p1000q1
how can i solve it please help me as soon as Possible please help
Sep 14, 2007 | Printronix Line Matrix P5215 Printer
Printronix Line Matrix P5005B Printer Logo
470 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
