Question about D-Link DIR-625 (790069292637) Wireless Router
I am unable to connect my wired or wireless computers to the internet through my dlink router. These computers were previously connected with no problems, however 3 days ago the internet stopped working
    President:
  • 1,194 Answers
You are advised to set up the D-link router once again. Below the steps re given on how to set up the router.
Set Up a D-Link Wireless Router
(1) Plug one end of the Ethernet cable into the DSL modem.
(2) Then plug the other end into the "WAN" port on the back of the D-Link wireless router.
(3)Connect wired computers to any of the other Ethernet ports on the router using another Ethernet cable.
Access the D-Link Configuration Screen
(1)Open your web interface and type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
(2)Use "Admin" as the username and leave the password blank when the login screen appears.
(3) Click "OK." You should now see the D-Link configuration screen.
Set Up General Security
(1) Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button. Enter a new password under the "Administrator" heading. Confirm it, and click "Apply."
(2) Disable the wireless Local Area Network (LAN) if you don't need to use the wireless access and you want to make sure no one else is able to access your network.
(3) Under the "Home" tab, choose "Wireless" and select the "Off" option.
Enable Wireless Encryption Protocol (WEP)
(1)Locate the "Home" tab in the D-Link Configuration screen, and click on the "Wireless" button. (2)Use the "Open System" button beside "Authentication." (3)Select the "Enabled" button next to "WEP," and set the encryption key to "128 bit." (4)Set the "Key Type" to "ASCII" and choose a 13-digit password for the "Key 1" field. (5)Write down the password in a secure location. (6)Click "Apply."
Change the SSID (1)Change the SSID to make it more difficult for others to locate and use your network by clicking on the "Home" tab and locating the "Wireless" button. (2)Change the default SSID to one of your choosing, then click "Apply." (3)Disable SSID broadcasting. Under the "Advanced" tab, click on "Performance" and check off the "Disabled" box. Again, click "Apply."
Filter MAC Addresses (1) Click the "Advanced" tab in the D-Link "Configuration" screen and select the "Filters" button. (2) Choose the "MAC Filters" and click on "Only Allow Computers with MAC Address Listed Below to Connect to the Network." (3) Enter the name and MAC address of the computers allowed to access the network, beginning with the one you are currently configuring. Click "Apply."
Thanks for using Fixya.
Good Luck and have a nice day.
Posted on Jun 06, 2010
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I can't connect to the internet with dlink router
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 06, 2010 | D-Link DIR-625 (790069292637) Wireless...
Wbr-2310 dlink router wired connection issue
connect your computer to the router by an ethernet cable. Open Internet explorer or FIREFOX. Type the roiuter's default IP-address (if not known: its either 192.168.0.1 or 192.168.1.1 or 192.168.0.0 or 192.168.1.0... keep trying until you're answered and asked for the password to enter the router (either attached on the router, in the manual or try: user: admin password: admin or password: password. Whgen you're in you'll find many checkboxes you could fill oput or notr; Easyway: give your net a name (SSID), then choose the network access security (set it to wpa-psk), choose a password and enable DHCP (then the router does the rest). Disconnect, look if the computer sjhows reception of your netwoirk by displaying its name. then connect. You will be asked for the password you chose. Done.
Jun 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
I am unable to connect to the internet with my dlink
Just connect my dlink 615 to a new dell computer on the vista page for the Network and internet the broadband connection is disconnected. What can I do to connect it? When I switch the dlink network back to the old computer everything works fine.
Aug 03, 2009 | D-Link Xtreme N DIR-655 Wireless Router
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Very slow, or no connection to internet, on wired computer, not wireless one
Yes, it would be best to reconfigure it. Try the following but note.. resetting the router will erase all previously given settings.
First, reset the router - when the unit is on, press the reset button (using a paper clip) for 20 seconds then let go of the button. Once the WLAN light is solid, it means that router has rebooted.
Go to a computer wired to the router and open Internet Explorer, enter http://192.168.0.1 on the address bar. Enter admin for the username and leave the password blank.
Once you're in the Dlink page, this is where you can configure your Internet and Wireless settings again. Just run through the setup process (as if you just got the device out it's box).
Nov 06, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink dir 300 internet problem
First you have to make sure that you connected it correctly. the cable coming out of the modem should be connected to the single port (Internet port) at the right when facing the back of the router.
All computers that are wired through it should be able to access the internet. if one of your computers cannot access the internet you may want to check the IP address that you are getting. (go to a command prompt and type ipconfig).
If you are connecting a wireless computer check the wireless security setting which you can find at the configuration (setup) page of the router. to access the configuration page check the owner's manual.
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
No internet connectin
Can you check if your laptop will still be able to get online if its in the same location where the non working wireless computer is?
Sep 04, 2008 | D-Link DSL-G604T Wireless Router
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
D-Link DIR-625 (790069292637) Wireless Router Logo
141 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
