Question about Bosch 24 in. SHX46A05UC Built-In Dishwasher
Doesn't seem to be getting enough water. - Bosch 24 in. SHX46A05UC Built-In Dishwasher
  • zoey56 Jun 06, 2010
    Thanks so much for your solution and the links to places on the net to get more information. Very well worth the price of membership!
  • 10,515 Answers
If there's no / less water entering your dishwasher, check these:
1. Water-inlet valve
2. Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Note - If the Machine is Under Warranty, it is advisable to Call the Manufacturer as the above Procedure might Void the Warranty, if any.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 06, 2010
  • 2 more comments
    Thanks for your quick reply. Were you replying directly to my particular model, or for all general dishwashers? I can't seem to locate a float valve or switch. Can you be more specific on where to find it on this model. Also, on the inlet valve, do you normally just replace it, or is there a way to check its function?
  • taran_2005
    taran_2005 Jun 06, 2010
    Thanks for your response!!
    Diagrammatic Representation would be :-
    http://www.appliancepartspros.com/partse...
    However, i could tell you the procedure .The Location of these Parts would almost be similar for all Brands.
    http://www.partselect.com/dishwasher+tes...
    Let
    Hope i helped you.
    Thanks
    Thanks for all your help! I removed the water inlet valve, took it apart, and found loads of sediment in it. It looks like granular sand that is transluscent greenish/blue in color. See below. Any idea where this stuff is coming from?
  • taran_2005
    This is really Common. With time, the Sediment might clog the Inlet Valve and could hamper the flow of water in the Dishwasher. You need to regularly clean them along with Filter.
    Let
    Hope i helped you.
    Thanks
My 96 dodge ram 1500 2 wd automatic doesn't seem like its getting enough gas while driving
Run fault codes checking for canister purge solenoid/valve Check fuel system pressure and pressure regulator.
Apr 07, 2013 | Cars & Trucks
My basket always overflows, the water doesn,t empty fast enough
Here is the SOLUTION(S):
1. Buy a sprayhead that restricts the flow2. Let the water flow through for a few minutes, then lift the lid while it flows through.3. Don't use Decaf4. Plug up a couple holes on your current spray head
Mar 24, 2012 | Bunn BT10B Coffee Maker
I have two problems with the Kenmore Ultra side-by-side refrigerator I inherited with my new house. 1) Water and Ice Dispenser do not dispense. Ice is being made but doesn't come out and water...
check the switches inside the panel where water and ice come out. that front panel comes off. this happened to me those switches are mounted on plastic mine broke and I used zip ties to put them back in place. The switches were just dangling there.
Aug 04, 2011 | Kenmore 53642 / 53644 Side by Side...
Mastercool doesn't seem to be getting enough water circulating
If the pads are old replace them. Take a panel off and look at the water dist. tubes if plugged, best method to remove it and use compressed air blow from the center, and let it rip, the basket maybe dirty. Good luck
Jul 02, 2011 | Mastercool 67471 Evaporative Cooler Air...
Have a 2007 vulcan 500, it doesnt seem to be getting enough fuel. It bogs down and wants to cut out and not at any particular speed.
Drain the carbs. chances are water condensation in the gas tank has built up in the float bowls. If that doesn't help, try a fresh set of spark plugs. Please rate my answer.
May 30, 2011 | 2007 kawasaki Vulcan 500 LTD
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Our freezer is cold but not cold enough at the top to make ice. It will freeze a cup of water at the bottom but doesn;t seem to be cooling enough. The compressor does come on and the fan is blowing. Is...
Get a thermometer, and place it inside the freezer. The temperature should get at least 17 degrees. If it is like 28 degrees or highe it will freeze water but not other things like some popsicles which freeze at lower temperature.
Mar 05, 2010 | Refrigerators
Dishwashers Logo
44 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
