Question about Refrigerators
I have a whirlpool gladiator freezerator and the top refrigerator does not get cold. It will cool a little bit but not much. I have noticed the rear of the refrigerator is very warm to touch.
  • 35 Answers
Check freezer compartment fan motor is working or not or else defrost timer must be prob
Posted on Jun 06, 2010
HOW to get to top of drain tube of Whirlpool gladiator GAFZ21XXMK00
Firstly it's probably blocked by a piece of corn or a pea or something similar, you have to totally defrost the unit by unplugging it, removing all the frozen food, then remove shelves, leave the freezer door open & leave overnight to dry out. Now tilt the unit back & wedge something under the front to hold it there, slowly poor very hot water towards the rear of the freezer compartment in the centre, it should not take long to clear the drain hole, you should be able to see it now, if you have any thin curtain wire or something similar, then gently poke it down the drain hole till cleared continue to use hot water till flowing, careful there will be a fair bit of water coming out the back, keep a few old towels handy, Good Luck.
Nov 25, 2013 | Gladiator Freezerator Top Freezer...
Freezerator leaking water into freezer that is freezing in bottom of freezer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Gladiator Freezerator Top Freezer...
An intermittent stream of water from the back top center shroud in the lower freezer section of our Gladiator Ref/Freezer is causing a lot of ice in the freezer. What's wrong?
This is caused by a design flaw in Gladiator Freezerators. The problem is caused whenever the auto-defrost cycle is active. This causes the frost on the coils to melt and flow to the drain tube. If the tube is blocked by ice having formed inside, the water has nowhere to go except down into the freezer compartment where it aagain freezes and forms an iceberg. The solution is to defrost the drain tube but this is only a tempo fix, because eventually it will freeze again. A more permanent solution is to remove the rear cover in the top compartment and expose the cooling coil and the defrost heater. Carefully wrap a 2-3 ft. long piece of bare copper wire, about 14-12 ga. several turns around the defrost heater and extend it down the drain tube located at the bottom right hand side of the drain tray. The little bit of heat transmitted down this wire is enough to keep the tube from refreezing. This fix is now available as a kit that Sears uses to take care of this problem but their kit does not work as well as the above. Good Luck!
Nov 14, 2010 | Whirlpool Gladiator Refrigerator
Water poors into lower section
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 27, 2010 | Gladiator Freezerator Top Freezer...
The freezer is frosting up on my Whirlpool Gladiator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 02, 2010 | Whirlpool Gladiator Refrigerator
Not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
gjfg
Apr 21, 2010 | Gladiator GAFZ21XXMK Bottom Freezer...
Whirlpool Gladiator Freezerator not cold
Just had the same problem on my Freezerator, the compressor would cycle on for a few seconds and then off for about 5-10 minutes. No cooling. Replaced the overload sw and the start capacitor and system running cold and tru. Beer cold again, 0deg in freezer. Parts are available on the web, P/n 2169373 for the capacitor and 213615000 for the switch and housing...may be different # for the sw....PTM
Jul 15, 2009 | Whirlpool Freezers
Build-up of a mountain of ice in freezer
replace the heater tube inside the freezer under the cooling fan good luck
Sep 22, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Refrigerators Logo
213 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
