Question about AEG Lavamat 16810 Front Load Washer/Dryer
Rubber frontseal came away from metal spanning ring (spanner) at bottom of compartment containing the clothes. How can I fix this? Thanks Ralf ps its a LAVAMAT 16810
  • 35 Answers
Gasket(rubber) is comes off means the metail spring may be damaged check the spring
Posted on Jun 06, 2010
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Sep 27, 2017 | Kenmore Washing Machines
Blanco Supreme 533-U sink drain leaking at seal
The sink basket/strainer that fits into the large hole of the sink should have either a bead of silicone sealant applied to the sealing lip of the assembly or a ring of plumbers putty. Silicone will work very well if the mating flanges are clean and dry.
With the baket in place, the rubber seal goes between the large nut and the sink. A bead of silicon on this is optional on the sink side of that rubber seal. and the nut tightened down snug , forcing some of the silicone out fro beneath the mating flange and rubber seal. Tight enough so the basket is not free to move. Be it plastic or brass/metal, that order is the same, only a plastic nut is not tightened as tightly as a metal nut would be.
On the bottom of the drain basket assembly there is a nut, to retain a plastic or brass tail piece. The plastic tail piece will have a polyetheylene "flanged washer" for a seal to the bottom of the sink basket. If it is a brass tailpiece, a rubber seal and metal nut is used with "pipe dope"/thread sealing compound used on the threads of the metal nut. With the plastic nut, you can apply a few wraps of teflon tape to the threads of the drain basket, but is not required in most cases as the poly flanged washer will form the seal. The plastic nuts should not be tightened any more than hand tight.
beneath that, the rest of the drain assembly attaches. If plastic- no more than hand tight. if metal, only about 1/4 turn past hand tight. Metal nuts and parts should use rubber gaskets/seals and the plastic parts should only use the poly tapered/lip seals.
Jan 15, 2012 | Plumbing
What tools do i need to change a inline fuel filter
If it is a plastic type, with rubber hose connections, then just a pair of pliers to remove the squeeze clips.
Nowadays most EFI cars have a metal body fuel filter with a "banjo" connection at one end. For this you need a socket wrench or ring spanner the right size.
At the other end is probably a metal fuel line with a compression fitting nut on it, which may be very tight. Here you need a flare nut wrench, which is a ring spanner with a slot to allow it go around the fuel line. Using an open end spanner or adjustable spanner may round off the nut if it is tight.
Nov 19, 2011 | Cars & Trucks
There is a black round, rubber (o-ring?) looking piece where the stem (where the container sits) meets the base. This rubber piece has melted partially away from its original position. Is there any fix (or...
not sure what size the o-ring is, but. Do you have a home depot nearby, and do you like the store. If so, bring the unit in, and go to the plumbing repair section. there you will find a wide varity of o-rings, assorted drain seals, even a make your own gasket mat. good luck to ya
Mar 12, 2011 | Vacuums
How to replace a belt tensioner on a 2001 ford focus
Creating More Workspace:
It is necessary to remove the CAC to inlet manifold pipe (drivers side) i.e. the wide, black pipe bolted to the top of the engine, to gain access to the P.S. pump and move the Engine Coolant Resevoir to one side.
Also, to make the process easier and create additional space, it may be helpful to remove the following additional items from the car:
  • fuel filter (and plastic retaining clip).
  • oil filter (to make access easier to the nuts bolts and pipes from below the car)
  • the EGR cooler connection pipe (optional).
Essential Items:
  • 15mm Deep, Hex Socket and large 15mm Ring Spanner - tensioner mounting nuts
  • E8 Torx Spanner for removing 3 studs with T40 Torx ends (method 2 only)
  • 18mm (or 3/8W, 7/16BS) Crowfoot wrench for removing union nut on HP pipe power steering pump. (method 1 only)
  • 10mm ring or combination spanners, long and short (P.S. Pump).
  • 10mm, hex socket ( narrower 3/8" drive preferred) - power steering pump bolts (Methods 1 and 2)
  • Hose Clamp (clamping bottom hose power steering pump)
  • Teflon seal / o-ring for union on HP Line, Power Steering Pump or new union (See Notes 2 & 3)
Nov 01, 2009 | 2001 Ford Focus
How to fix 2 red lights on xbox 360 something about overheating
DSX-1 interface. Pinouts for each of the RJ-48C jacks are RCV to the DSX-1 from the span on pins 1 and 2, .... DSX-1 Drop. RJ-48 C, terminal blocks. Power Supply Options ... HiGAINMINI SHELF. INPUT: WITH PS 100/120 VAC. 1.0A 50/60 Hz
Sep 10, 2009 | Microsoft Xbox 360 Console
Hotpoint WT960 Flashing F-05
This is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.
Sep 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
How do I replace the solution tank valve?
Mine has done the same thing twice. I don't think you can store any unused solution in the container because it eats away at the rubber o-ring causing failure. You need to pull out the rubber housing by hand or gently with a pair of pliers.
Mar 06, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
AEG Lavamat 16810 Front Load Washer/Dryer Logo
137 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
