Question about GE DVL223EBWW Electric Dryer
Bought new timer for Prodigy but thought i set the wires from the old timer in proper sequence but doesnt work so maybe wrong wires on wrong terminals
  • dstetzo Jun 07, 2010
    THERE is no schematic where the expert says i should check. This is a GE Prodigy model # DPR483EAOWW and the timer #WH12X10193 and I need to know if i have the terminals on the right lugs of the timer
  • GE Master
  • 8,220 Answers
Look at the wires. They have markings on them that match the markings on the timer. Did you check the Non-resetable limit? If it is open the dryer will not run.bought new timer for Prodigy - 89819b0.jpg
More here
Posted on Jun 07, 2010
  • GE Master
  • 3,740 Answers
Reverify the wiring terminal connections per the schematic inside the top panel. After verification you should check the door switch for an audible click as the door is just opened or closed. If that appears to be working then the motor switch on the outside of the motor has failed.
If you have a meter check the input wire to the timer from the door switch for power. If there is no power you will need to follow the schematic and check to see if there is power to the motor switch.
Here is a typical dryer schematic:
http://www.appliancerepair.net/apnet/dryer/02-06.gif
The power on almost every basic dryer goes from L1 on the terminal block to the door switch, then to the push to start switch, then the motor and finally to the neutral connection of the terminal block. If you do not have this power anywhere go to the main CB panel and turn off the breakers (Physically push the breaker to OFF) and then back on. Recheck for power L1 to N (120V), L2 to N (120V) and then L1 to L2 (240V) If you have these voltages after resetting the Main Panel CB your dryer has the correct input power.
If you need more assistance after rechecking the timer connections per the schematic inside the top panel and verifying power just respond here and I will do my best to help you.
Thanks for using FixYa.
Kelly
Posted on Jun 06, 2010
  • 2 more comments
  • Kelly
    Kelly Jun 07, 2010
    The packet for the technical sheet should be inside the dryer. Usually they are innside the top panel in the envelope packet. The technical sheets are either in a 4 x 6 envelope of a 2.5 by 4 envelope that is glued to the chassis. If yours is not inside the top panel then remove the back of the dryer and look on the sides of the chassis and the back panel itself for the tech sheet envelope/packet. It can be labeled technical data or product specific data.
    Kelly
    the doucments from dryer are not timer specific, therefore i am still stuck i just need a darn spicific diagram of the color coded wires and which terminals they connect to
  • Kelly
    Kelly Jun 07, 2010
    I have looked in every GE Dryer service manual I have and do not have the model specific manual for your 483 dryer. Hopefully there is another expert that can help you with wiring terminal specific / color coding to terminal connections. I was pretty sure the tech sheet had 2 letter color codings for the wires. R=Red T=Tan BK=black WT=White etc. Some of the timer terminals are X, M, T and S. (from memory) I am pretty sure there are 4 terminals on the bottom (3 one of which has 2 terminals) 2 terminals on the side near the timer motor and 3 on the top. Without ordering the service manual for your specific Dryer I just have run out of ay other options to resolve your issue. Just being honest. Again hopefully another expert has the manual with the information you need. You may want to post this response as a quote so that other experts can see your needs. The will not see it unless you do quote my response in YOUR response as it is usually an individual response from EACH expert. I will watch the post for a day or 2 for a solution and if it is not resolved I will personally consult with other experts for you to try and get you going.
    Kelly
  • Kelly
    Kelly Jun 09, 2010
    There is one more item that can stop power from reaching the timer and that is the belt safety switch. If the drive belt is worn or the switch is out of adjustment, the dryer will NOT start.
    Kelly
Bought new heat sequencer ,took old one of so i would know what to get did not note position of wiers need to know how to reconect wiers
one of the larger set of wires is your heater element common. the other one goes to the common to the sequencer line side. the control wires are smaller. one is common to the coil(s) the others go to the timers that kick in the elements one at a time for heat as it is desired.
Oct 19, 2009 | Heating & Cooling
Tip
How to service a timer
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty.
- Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
- To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
- To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
on Jan 16, 2010 | Washing Machines
Maytag atlantis washer mav9600 washes and agitates and drains, but won't spin. help
I suggest testing theServicing the Timer
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
selector switch,
Sep 09, 2009 | Washing Machines
Washer spins out but will not fill or agitate
You most likely have a bad timer. If machine is filling properly, then the switch is bad.
Servicing the Timer
Sep 03, 2009 | Kenmore 24032\24036 Top Load Washer
Replace Timer Assembly on GE WJRR1470E1WW Washing Machine
Servicing the Timer
In the next section, we will examine two of the most crucial elements of a washing machine -- the water inlet valves and the agitator.
Apr 09, 2009 | Frigidaire FWS833A Top Load Washer
When switched on with a load in it works through the first setting, then the dial just keeps clicking around to the next setting repeating over and over. the only way i stopped this was to switch the power...
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Nov 06, 2008 | Washing Machines
Error code on bosch washing machine wwwf 2000 3 flashes of prewash light
HI
Oct 13, 2008 | Bosch Washing Machines
I have error F:16 on my washing machine.its an excell 1400S express
HI Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Oct 12, 2008 | Bosch Washing Machines
Display flashes and counts down but will not wash. the dial doesn't work to change program and I can't clear the display to select anything else.
Oct 10, 2008 | Haier Washing Machines
I need to know how to replace the timer-mall on my Amana washing machine model #ALW780QAC
hi here steps Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Sep 12, 2008 | Amana Washing Machines
GE DVL223EBWW Electric Dryer Logo
309 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
