Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Broken USB module
I have a WD Element, my dog dropped it and now the USB module is broken. What is the replacement part for this n\and where can I find it.
Thanks
  • rccordero Jun 06, 2010
    I thought the same, I've been looking into the HDD cases but I'm not sure if they are compatible with my HD (WD 10EAVS). Is this a viable option?
  • 39 Answers
Inside on the PCB board or outside on the cable? If inside, you will have to remove the connector & solder in a new one. I doubt this will be worth it in terms of time you'll spend doing this. Also, you will have to open the casing to get to the board. So, then, why not just take the drive out & hook it up to a computer to either retrieve the data or to use as a secondary disk. Go buy another external drive to replace the previous functionality. This will be far cheaper than trying to do a component level repair.
Posted on Jun 06, 2010
  • coz Jun 07, 2010
    Sure. Unless it's a real old external drive, it likely houses a SATA drive. Most external cases are about the same. Expensive ones have built-in intelligence (embedded linux server, for instance) and network connectivity. For everyday home/office use, a cheap one should be available for anywhere from $15-$50. I don't know what area you live in, so I can't give you local stores, but BestBuy will sell you one at a decent profit. Or, you could get one on buy.com or newegg.com if you don't mind a day or two in shipping. Just pay attention to cooling (active or passive). 2.5" run cooler than 3.5" and you can get away with passive. But, for 3.5, I'd make sure the case has a good (& quiet) fan.
Feed dogs don't seem to be working right.
the feed dogs could be broken or the lever that raises the feed dog could be broken, needs to be serviced
Sep 22, 2015 | Janome HD3000 Heavy Duty Mechanical...
Feed dog not feeding
The machine needs to be with a stitch length above zero.
If the machine has a switch that makes your machine go into free arm that will also cause this.
The only other thing is a mechanical problem which will need to be repaired.
Jul 28, 2015 | Sewing Machines
My WD my passport not working
maybe the cable plug of the WD my passport is broken
Apr 18, 2013 | Western Digital My Passport Essential...
I have Element powered by WD. Hard Drive. I need to buy AC adapter is broken.Nr, DA 30C01- I live in Norway , please tell me where i can buy this adapter.
The solution to this problem is to contact your nearest computer store. They may either order one for you or have one on hand.
Take care!
damnor01
Jul 16, 2011 | Western Digital Elements powered by WD 320...
I dropped my WD Passport on the floor and it got disconnected from the usb cord drive cable, when I plugged it all back in and plugged it on my pc it doesn't shop up anymore, how do I fix it?
Sadly you don't.
Dropping a hard drive and having it still work is something you should never expect.
You could pry the case open and put the drive it in an empty external drive case and see if it works, or try a new cable, but the most delicate part is the drive mechanism itself, and if anythings broken, that is most probably it.
You could probably get a replacement, maybe not WD, for around $60 and one I got on special $70 including postage from an online seller a few weeks ago had a 500GB WD drive in it.
Feb 06, 2011 | Western Digital WD Passport 250GB Portable...
My WD external HD "element" will not turn on
When you say it won't turn on, do you mean, there is no spin-up and not LED. If this is the case disconnect it from the power source and then reconnect it. If the LED flashes once or doesn't appear at all, the power supply is faulty and you will need a replacement. If you call WD, they will send you a replacement power supply free of charge.
Jan 20, 2010 | Western Digital Elements powered by WD 320...
Broken USB connection port on WD 500GB Mybook
I had the same problem and I solved it. Slip off the black case and replace the part thats broken. its cheap. $10 here is the link: http://www.centrix-intl.com/details.asp?productid=9501
I HOPE THIS HELPS!!!!
Jan 11, 2010 | Western Digital My Book Home Edition 500...
Broken usb housing on WD 500 gb my book
You should be able to take out the 3.5 drive that is inside and move it to a new enclosure (does not have to be WD) Tiger Direct has them. You can find them at BestBuy or online for less than $40
Jul 26, 2009 | Western Digital My Book Essential Edition...
Broken pin on usb outlet
contact wd for a replacement part.
May 04, 2009 | Computers & Internet
Usb is broken on hard drive
Do a web search for data recovery.they are high priced but will attempt to recover all info. Most will place recovered data on a brand new harddrive at no additional cost.Suggest picking several and calling prior to mailing. RICHARDM69
Dec 09, 2008 | Western Digital Passport WDXML800UE...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
142 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
