Question about Acer Computers & Internet
How to restore acer aspire 9410 back to factory
How to restore acer aspire 9410 back to factory setting
SOURCE: restore settings
hi the above is not true ..i have restored many acer laptops ..its very easy to do ...start the computer up you will get the acer logo first then a black screen with a cursor in the top left corner (this only stays on for a few seconds .) when this screen (black screen with cursor) comes up immediatly press alt and f10 this will then bring up a screen that says windows system restore ..just follow the on screen instuctions the first one will be 4 options as to what you like to do ...you need to do complete factory restore (think its the first option) and thats it just follow what it does and asks you to do ..be aware that you will loose everything you put on the laptop ..that wasnt already there when you purchased it ..every computer has a original copy of the factory settings and windows hidden on the hard drive ..your computer will be restored to the brand new condition it was in when you bought it ..dont worry if it seems to take a while and doesnt look like its doin anythin.it is and can take anything from half an hour to an hour for it to do it all...the computer companys and fixers dont like you to know this but trust me ive done loads of acers this way ..and sonys and gateways ..the trick is is to no what buttons to press on start up to access the windows restore facility ..an acer is alt and f10 ...hope that helps.
Posted on Oct 18, 2008
zohail
  • 1223 Answers
SOURCE: restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
Posted on Apr 13, 2009
  • 3 Answers
SOURCE: acer aspire 6920 back to factory settings
on the first screen that says something like "F2 to enter BIOS" and "F12 to change boot order", hit F10 (maybe Alt+F10 or Ctrl+F10, not sure) and it should pull up the recovery console.. just read carefully, the only option there might be reformatting C:
Posted on Jun 22, 2009
  • 52 Answers
SOURCE: restore back to factory settings
From Acer direct
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
todd0708
  • 247 Answers
SOURCE: acer aspire password to restore to factory settings
well if its the boot password you have hope,ALT+F10 on start is supposed to get you to the recovery manager,if you cant get there restore factory default,if its the windows operating system password,you can try to type administrator in the user name and leave the password blank,sometimes your able to get in on the built in administrator acct.,if that doesnt work,,its not easy you can download password recovery programs and try that,if its the boot lock password you can take it apart and remove the bios battery on the mother board,remove main battery ,unplug power set something on the power button heavy enough to hold it down and wait,the longer the better,one day ,maybe two,reassemble and it should be back to factory default, if its under warranty send it to acer,nowif your able to get past the boot password and the windows password is still holding you up you can one-time boot to a windows disc and reinstall new copy,warning! you will loose everything on the computer,but at least you can use it agian hope this helps,aloha from maui todd0708
Posted on Nov 12, 2009
Restore to factory settings
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to "Start" > "Restart" to reboot your netbook.
Hold down "Alt" and "F10" when you see the Acer logo on the screen.
The recovery menu will load.
Hit "Enter" and then "Next" to see your recovery options.
Choose "Factory Restore" to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
Jun 13, 2013 | Acer Aspire One Netbook 8.9" Notebook
Aspire one needs rebooting no disk
The Acer Aspire One is a netbook, not a laptop. A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop. It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature. You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive.
Feb 14, 2013 | Acer Aspire One PC Notebook
I dont know how to restore my acer with linux back to factory settings
Jan 20, 2013 | Acer Aspire One Netbook 8.9" Notebook
I DONT KNOW HOW TO RESTORE MY ACER BACK TO FACTORY SETTINGS
Jan 20, 2013 | Acer Aspire One PC Notebook
Acer aspire 9410-4317 was reformatted to windows 7,how can i get original factory settings back?
If you did not delete the recovery partition, you can do an eRecovery:
http://acer.custhelp.com/app/answers/detail/a_id/2631
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 28, 2011 | Acer Aspire 9410-4317 Notebook
I have an Acer Aspire 9410 and I lost sound
try system restore by going to Start menu-> All Programs -> accessories-> System tools-> system restore-> select a date the system was working fine with sound
Jul 04, 2010 | Acer Aspire 9410 Notebook
Acer e Recovery Error code: 0xC0000003Open image failed. Found
The image stored on your laptop to restore it to factory original is corrupted. If the laptop still boots, try to make restore media using the acer erecovery management console, although this will likely not work if the image is corrupt. Try installing windows with these discs if you can. If not you have 2 options:
  1. Contact acer and order restore discs (free if in warranty) or about $50 out of warranty.
  2. Reinstall windows using an OEM Windows cd and the keycode on the windows sticker on the bottom of the laptop. You will have to download all hardware drivers manually though, and you will not have any of the softawre provided by acer. The restore discs from acer are by far the best option....Let me know if this helps.
Aug 08, 2009 | Acer Aspire 5720 Notebook
Need to restore acer to factory settings
contact acer you can get there number from the website and they will let you purchase a restore disc for 15bucks
Aug 20, 2008 | Acer Aspireā„¢ T180 PC Desktop
Computers & Internet Logo
964 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
