Charge your Philips GoGear ViBE for at least three hours before turning it on.
Insert the small end of your
mini USB cable into your GoGear ViBE. Insert the other end of this cable
into one of your computer's USB ports. Turn your GoGear ViBE on by
pressing and holding the "Power" button for two seconds.
Insert the Philips GoGear ViBE software disc into your computer's CD-ROM drive. Follow the onscreen prompts to install it.
Open "Computer" from the "Start"
menu and locate the GoViBE icon to make sure it has been successfully
connected to your computer.
5
Navigate to your music files. If
you're unsure about their location, start by looking in the "Music"
folder under the "Start" menu.
6
Drag and drop your music files from their folder onto the GoViBE icon in your "Computer" window.
7
Right-click the USB icon with
the green arrow, located in your taskbar, to disconnect your device.
Click "Safely Remove hardware," then wait until your computer confirms
that it's safe to remove the device. Disconnect the USB cable from both
your computer and your GoGear ViBE.
8
Select the musical note icon
from the main menu of your GoGear ViBE to open your music files.
Navigate to the sub-folders section, and select a song from either the
artist, album, track list or genre. Press the "Play/Pause" button to
begin playing a song
1...You must download and install Windows Media Player 11 on your computer. NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11. If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10. 2...After you have downloaded and installed Media Player on your computer. 3...Open Media Player on your computer. 4...Install all your music into Media Player that you want to install on your MP3 player. 5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on. 6...Media player should recognize the MP3 player and sync with it. 7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player. Free Answer...Please take time to rate me
there is an update for windows 7 and dongles at the husqvarna viking website.
From Husqvarna Viking website -
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
Install your 4D Embroidery System software (and all updates).
Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
If you are still unable to get it to work, visit your local authorized Husqvarna Viking dealer. Most stores have staff who are eager to help but you might want to call for an appointment
Info on Husqvarna Viking website - http://www.husqvarnaviking.com When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7. Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules. Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers. Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe Good luck.
Subscribe to an online music service that is compatible with your GoGear, such as Rhapsody's Mp3-Only service - I repeat MP3 ONLY - no other Rhapsody service will work. Use Windows Media Player to transfer songs to your GoGear, or Rip CD's into Mp3 format - I repeat MP3 FORMAT - using Windows Media Player.
Videos must be transferred using the Philips (Arcsoft) Media Converter that came on the installation CD. You can also get this program from Philips website.
You will only be able to transfer photos to your GoGear if you have used the installation CD that came with the player. It contains a critical file that Philips has never posted to their website called the Philips Device Plug-In.
