Question about West Bend HiRise TM 41300 Bread Machine
The machine fell off the counter during its kneading cycle
The menu display does not work anymore
  • 619 Answers
SOURCE: Broken Lid on WelBilt Bread Machine Model ABM1H70
Hi , try to visit the web site of fixya recommended site : Alibaba.com
Posted on Mar 20, 2008
greenspan
  • 1734 Answers
SOURCE: machine stuck during kneading cycle
Check here:
http://manualfox.com/link/westbend.htm
They can get you any West Bend manual. Just send them a request.
Posted on Jul 08, 2009
  • 433 Answers
SOURCE: my bsread machine vibrated off of the kitchen
If you can find all these parts on Ebay I guess they would be expensive. I replaced my bread machine for around $50.00 at Wallmart. I would guess parts on eBay would be equal or more than that.
Hank (just my opinion)
Posted on Jan 29, 2010
  • 433 Answers
SOURCE: my machine seems to labor in the kneading cycle,
Hi, Take the pan out of tha machine and see if the paddle spins freely by hand. If yes that's great...if no then the sealed bearing might be sticking and starting to fail. Next check the tension on the belts. The motor and belts are located in the base of the machine. Be sure to unplug machine and ask someone to help you if you are not mechanically inclined. Hank
Posted on Sep 23, 2010
  • 433 Answers
SOURCE: First bread machine, one paddle would not spin,
Hi...The black gunk under the paddle seems to be caused by the sealed bearing located on the bottom of the bread pan. When this seal breaks the lubrication leaks out. It's a problem with the bread pan and not the machine. Seems the new machines cost more and are made with really cheap bread pans. I've had good luck with my Sunbeam and it's warranted for a year. Just my opinion....Hank
Posted on Jan 18, 2011
When do i add raisins,nuts,etc. during cycle?i have chefmate #hb-12w
You machine should beep several times before the end of the knead as a signal to add things. If you don't hear it just add them when there is 7 minutes left of the knead cycle.
Jan 25, 2011 | Chefmate Kitchen Appliances - Others
First bread machine, one paddle would not spin, also black gunk accumulated under paddles - great customer service - bread machine replaced. 2nd bread machine, another malfunction - again, great customer...
Jan 17, 2011 | Black & Decker B2300 Bread Machine
Bread machine, mechanical problem (American Harvester Classic)
Let's try a few things. First take the bread pan out of the machine and see if you can spin the paddle freely by hand. If you can't, then the sealed bearing in the bottom of the bread pan is frozen and the paddle won't spin during the kneading cycle. Try putting hot water in the pan and let it soak. Try this a few times...If that does not work you will need a new bread pan. If everything is good with the bread pans, then take both pans out of the machine and start a kneading cycle. Look through the top window (if you have one) and see if the motor shafts are spinning. If not, then the belt fell off the pulleys, or has snapped, or the motor is broken. Good Luck..Hank
Jan 17, 2010 | Kitchen Appliances - Others
When i put the ingredients as directed, i selected the program then put the delay on. when i woke up expecting fresh bread, i had a hard 3 inch brick with flour and yeast sitting on top of it. was i...
No, Everything should be done automatically. It seems that the machine did not knead the dough. Two things may have caused this. 1) The paddle is frozen and wont turn. Take the pan out of the machine and see if you can rotate the paddle by hand. If yes...that's cool, if no then the sealed bearing that the paddle rotates on is jammed or broken. Try filling the pan with warm water and let it soak. If after a few times it's still frozen, then the bearing is broken and bread pan needs to be replaced. 2) Belt fell off or is snapped. Keep the pan out of the machine and go to a kneading cycle. Look through the window on the lid and see if the motor shaft is turning. If no... the belt fell off or snapped, or the motor is broken. Good luck..Hank
Dec 03, 2009 | Oster 5836 ExpressBake Bread Maker
I have a brand new West Bend "just for dinner" bread maker. In the bottom, the two-pronged part which the motor is supposed to turn, doesn't turn. Thus, the kneading spatula doesn't turn. The heating unit...
If the machine is brand new, then take it back for an exchange. If that's not possible, then call West Bend for a replacement. If that's not possible then let's try to solve this problem in a few steps. 1) Take pan out of machine and see if you can spin the paddle on the shaft. If yes...next step..if no then bearing in bread pan is stuck. 2) Put bread pan in machine and lock in place. Start a kneading cycle. Look through plastic lid to see if paddle turns. If no step 3. 3) Take pan out of machine and start kneading cycle. If motor shaft does not turn, then the belt fell off the pulley in the machine or belt is broken, or the motor is bad
Hank
Nov 15, 2009 | West Bend 41077 Just For Dinner¿...
Machine stuck during kneading cycle
Check here:
Apr 02, 2009 | West Bend 41089 Bread & Dough Maker
Loaf falls in the middle and outside is hard
Falling in middle is usually due to innacurate measuring of liquids. Try again using the instruction manual's recipe and very carefully measuring. Be sure to adjust the liquid if you use honey or other liquid not called for in the recipe.
orleydog
Feb 01, 2009 | Oster 5836 ExpressBake Bread Maker
Mar 17, 2008 | Kitchen Appliances - Others
West Bend HiRise TM 41300 Bread Machine Logo
97 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
