Question about Kenmore Refrigerators
My ice dispencer keeps icing up inbetween the botom of the ice holder and insde the chute delivery door.
  • 10,865 Answers
Turn the temperature in your freezer to the next warmer setting. Also use a blow dryer to remove the ice and the moisture. Wait two days and see if that has solved the problem. If it is still happening go one more setting warmer. Jo
Posted on Jun 06, 2010
    Novelist:
  • 238 Answers
The door of your refrigerator can not be closed completely so there is an air flow from outside to inside and also from inside to outside. This refrigerator uses more electric for this. The problem can only be solved by finding the hole and closing it.
This problem generally occurs because of the legs of the refrigerator.
Set the legs equally.
So you should find the problem and correct it.
Also this generally happens after cleaning.
I hope it helps.
How do i unthaw the delivery chute without breaking it?
Take everything out of your freezer and store it somewhere else (like another freezer, or cool bags with ice packs.
Leave the door open with a towel hanging over the top to prevent it from shutting. Disconnect the freezer from the mains and leave it for 48 hours to completely defrost.
The floor will get wet, so prepare for some mopping!!
Jul 24, 2014 | LG 21.0 Cu. Ft. Counter-Depth Side-by-Side...
The ice dispencer keeps backing up and I can't get the ice bucket to come off the freezer door. Help please!!!
must be a whirlpool / or ka . open the door and let it thaw then remove it and de ice it with hot water . dry ir good and the ice delivery shoot .. spray the dry surfaces wth food grade silcone and this will helt for a while . do this about every 3 mo to prevent this prob . mm
Oct 13, 2010 | Maytag MZD2766GES Side by Side...
Ice despencer opening keeps freezing and wont dispence
you have a bad door seal. replacement is better than repair. warm moist air is getting in and the condensation is freezing.
Nov 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Little door that lets ice fall into glass won't
need to check door chute hinge it could be broken
Nov 05, 2009 | Kenmore Refrigerators
Ice maker dispencer on Kenmore model 58082 seems to freeze up in chute.
either door chute is worn out and need to be replaced or door is not clossing at all. could be the hinge is ajar
Nov 03, 2009 | Kenmore 58422 / 58429
What is the part called (the little flap that closes after Ice comes throught the dispencer?
it's called an "ice chute door". Look on sears.com, select "Parts Direct", another page will come up, enter your model number of your frig, then enter, wait a few then your model info will pop up, select either the freezer door or if it has "Ice & Water dispencer" select it, wait for another page to come up, then look thru diagram for part you are looking for, then scroll down to that part number and you will be able to see actual mfg part number. There should be a "Ice Chute Repair Kit" listed as that is how they come. Search internet for best price.
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
