Frigidaire PLMV169DC Microwave Oven Logo
Posted on Jun 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a electrolux 1000w above range micro that stopped heating...maybe a fuse? Where is fuse?
Anonymous
Level 3:
President:
  • Master 2,702 Answers
  • Posted on Jun 06, 2010
Anonymous
Master
Level 3:
President:
Answers
2702
Questions
Helped
910665
Points
7895
If a fuse has blown then its very likley there is a fault inside this microwave,,,as for poking about inside it,,,dont!!!! even if you unplug it from the wall socket there will still be 1000's of volts kicking about in it and they can kill you if you tuch the wrong part,,,,is this risk worth taking???? its up to you!
How do I change a micro switch?
how do you know the switch is bad?maybe it is the fuse thats inside the microwave
Replacing Micro Magnatron
No, every one is designed for the inverter and circuits in that unit.
If it has a turntable does it move?
I was heating up water and micro stopped working and now it will not turn on
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
0-0-0-0-0-0-0-0-0-0-0-0-
Does not heat
I WOULD SAY REMOVE THE CABINET FIRST AND GO FROM THERE. IF YOU HAVE NO POWER THAN CHECK THE FUSE.
Mw will not heat
usually if MAG is RF dead the unit will function but not heat...
Microwave not heating items
if it is fuse then there should be no lights or display at all. if there is, then it is not a fuse. it could be the magnetron.
the fuse is located inside the microwave. you have to bring it down and open the cover.
i hope i was able to help
pls rate me..
tnx ,
drcool
1helpful
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Frigidaire Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
