Question about Frigidaire FEQ1442ES Electric Dryer
Dryer runs when door shuts. Only stops when door is open
Have a feq1442eso model dryer the drum turns when you shut the door. Only stops when you open the door. Whats the problem?
  • Anonymous Mar 29, 2014
    kenmore dryer will not stop when buzzer goes off even when you open door
    President:
  • 512 Answers
There is a safety switch in the door that shuts dryer off when door is open. If there is more to your problem let me know. From what you have stated there is no problem.
Posted on Jun 07, 2010
Hunter, I have A kenmore electric dryer model 110.64121100. My problem is the dryer heats but the drum does not turn. This is a very strange problem. I turned off the timer and heater was still on in the...
Ok check the belt. if broken then make sure the drum turns freel by hand before replacing the bely. Usually dryers wont heat if the motor doesnt go so perhaps the motor is running without a belt. have a look see. Without an inspection its dificult to pin point Good luck
Jan 22, 2011 | Dryers
Dryer doesn't run
the motor is going bad..push in the door switch on the dryer,an it start an spin the drum ,it it works,replace dryer motor,or purchase a new open....turn start button,pusn in door switch,spin drum by hand...all at same time....hope this helps...dryer may run a couple of times...good luck...michael..doctor airr appl.repair...843-384-8474....
Mar 26, 2010 | Dryers
Kitchenaid dryer keye660wwhi stopped working 30 seconds after turning on. i opened the door and closed it and it turned on again only for it to shut off again in ten seconds.Now it won't even turn on at...
your door latch is getting loose and ont holding the door switch in far enough to make contact,open the door,keep your hands out of the drum and push in or on the switch and see if this fixes the problem and the dryer runs,then just replace door catch hardware
Jan 31, 2010 | Dryers
Runs for a while than shuts off if i take the back off it doesn't shut off.
Usualy this is caused by poor airflow through your dryer. Remove the lint filter and check for a lint build-up near the bottom of your lint filter. If you see a lint build up use a vacuum crevice tool and something long like a fly swatter to loosen the lint as you vacuum. Also check the dryer vent tubing and the outside vent flapper for obstructions. What is happening is your dryer is heating up until the high temp limit protection rhermostat shuts off the heating element.
What I just mentioned is apparently not your problem. You said that your dryer runs then shuts off completely. Check to see if the motor is easily roated by hand with the belt installed. If it is difficult to rotate there is a bearing problem somewhere causing heat to build up in your motor until the thermal overload shuts off the motor. There is a drive belt idler near the motor that can also cause excessive drag on the belt if the bearing has failed. The last thing to check would be the drum rollers located in the groved area on the outside of the rear of your dryer drum. If these have stopped turning they act like a drum brake and can also cause the same symptoms. Removing the back panel allows the chassis to shift enough for the drum to ride lighter on the drum roller even though it may not be turing it is enough for the dryer drum to skid / slide on top of the stuck drum roller yet not shut off.. Hope this helps and good luck. I can help with access issues need be here.
One question I have is does your dryer door open and close properly? Some times a bad door seal or door catch can cause the same symptoms. Open and close the door and losten for a switch click as the door opens or closes not far from the closed position.
Jan 06, 2010 | Kenmore 62602 Electric Dryer
Dryer drum is turning, but not drying the clothes. When I open the door, there is heat. Lint has been cleaned out
Check where the dryer vent comes out and make sure that there is a good amount of air coming out. If the fan is blowing, the drum is turning, and there is heat, the likely thing is that the dryer vent is partially blocked. Check the pipe leading out. Bird's nests are not uncommon. The only other thing I can think of is that the door catch is wearing out and the door is popping open, shutting the dryer off mid-cycle. Some dryers will continue to run the timer if the cycle is interrupted and it will appear that the dryer ran its full cycle, but in reality it shut off soon after it started.
Dec 06, 2009 | Whirlpool Inglis IP8200 Dryer
Won't shut off unless the door is opened
Usually the only thing that will stop the dryer is to open the door or turn the timer to the off position.
Nov 24, 2009 | Dryers
Wont start door shut tight can heat timer drum lite on when door open
If you can hear the motor running with door is closed and the dryer is turned on, the the belt that turns the drum is likely off the drum or broken.
If you cannot hear the anything when the door is closed and the dryer is turned on, then the door switch is likely defective.
The other more unlikely causes are either the Timer or Switch that starts the dryer is defective.
Aug 21, 2009 | Kenmore 400 6942 Dryer
Drum runs continuously
Sounds like you have a shorted relay in the door switch. If you know a good electrician or repair man I'd give them a call.
Nov 16, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
232 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
