Question about GE WSXH208A Front Load Washer
GE Adora Front Load Washing Machine Problem
My GE Adora front load washing machine will lock the door, spin to the left a couple of seconds, spin to the right a couple of seconds, then unlock the door. It does this with no water inside and will not cycle at all. it started with an uneven load , washer would not spin water out. so I removed the load tried again, it would spin to left a little then to right then stop the door would unlock and it will not finish the cycle, the delay button was pushed during all of this. is there anyway to reset it or cancel the delay, also can you tell me where i find the pump filter to check if it needs cleaning.
    Master:
  • 351 Answers
Dear Trudz,
all you need to do is clean the filter. you can get to it by unscrewing the front screws at the bottom to remove the bottom panel. Unscrew the filter but be ready to have something to catch the water overflow. Coins did it for us. There was not much lint. Hope this helps.
Cheerup and be happy always
Posted on Apr 10, 2008
    Brigadier General:
  • 6,966 Answers
Have you tried a full hard reset? This is simply unplugging the unit from the mains for a couple of hours.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Apr 10, 2008
    Hi again,
    On your pump filter query:
    1. remove the 3 screws (use a Philips screwdriver) that hold the front inspection panel on;
    2. with the panel removed, there is a large, easy access filter with a screw top lid;
    3. twist open/unscrew the white or gray cap, that's the filter plug;
    4. you might be surprised with that is stuck there that blocks the water flow;
    5. Once clean and done, put the filter back, re-seat the inspection panel, put back the 3 screws and plug in the washer.
    Caution, there might be a lot of water. Additionally since you will be working on the internals of an electric powered device, please work safely and make sure that the unit is unplugged while performing the cleaning.
    Cheers.
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
GE Adora front load wont lock the door or start at all. GE service is not existant.
the door switch has broken and needs replaced can be got online,adrian;;;;
Nov 11, 2009 | GE WSXH208A Front Load Washer
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Water left in washer
You must change new pump.
Feb 15, 2009 | GE WSXH208A Front Load Washer
Washer won't drain
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Aug 05, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE WSXH208A Front Load Washer Logo
508 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
