Question about Olympus EVOLT E-500 Digital Camera
Pictures have a blue hue when using auto setting
    Brigadier General:
  • 11,967 Answers
Do you have the white balance set to something other than "auto white balance"?
Posted on Jun 06, 2010
Why does my Samsung LED TV now have a permanent blue hue to its picture?
The t con board digitizes your picture and is responsible for anything you see on the screen including any and all anomalies. I would go that route TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2017 | Samsung Televison & Video
Flash goes every time, even when there is no lightning bolt in the screen (for lack of better terms). Also a few photos turn out blue that were taken indoors.
210 wide camera is auto detect the environment. If you face it under bright light, the flash will auto off, if away from bright light, it will auto have flash. for photo have blue hue do show me the image, i take a look
Jan 10, 2014 | FUJIFILM Instax 210 Film Camera
Red blue hue on picture
ur color setting has certain problem. from ur remote control go to color setting and set ur req.color
Mar 10, 2012 | Televison & Video
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Looks like 3D tv
Try doing a calibration. Projection TVs work with 3 picture tubes (Red, Green, Blue). The Red may be off to one side causing the hues.
The manual is available here for instructions on how to perform calibration:
http://www.retrevo.com/samples/Hitachi-manuals.html#Projection%20TV
Apr 06, 2009 | Hitachi Televison & Video
Taking still pictures all show up with an orange hue
This could be because you have set the White Balance to Fluorescent. Set this to Auto and it should be fine.
Feb 11, 2009 | JVC GZ-MG330 HDD Camcorder
Color off seems amber
Double check the wb settings in camera, (and be sure to check WB Shift) I'd suggest adding a Blue shift to your images to compensate for the Amber until you find something thats a decent trade off, if you can't eliminate the amber shift.
Dec 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Blue Hue
On a digicam, autofocus works by looking for areas of contrast in the image you are framing. So if you are taking a picture of people (who usually have little contrast) and there is something in the frame (such as a building in the background) with more contrast or sharper definition, the autofocus may focus on that item and not your subject. Knowing this, your job is to work with your camera's modus operandi to get the shot you want. One way is to zoom in, lock the focus on your subject (by pressing the shutter button halfway down) and, while still half-pressing (or switching to manual focus if you have that option), zoom out to recompose. Sometimes you can change perspective or backgrounds to give your subject better contrast. Also, aim for areas of high contrast, such as edges.
Mar 21, 2008 | Fuji FinePix A345 Digital Camera
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Olympus EVOLT E-500 Digital Camera Logo
115 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
