SOURCE: Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
SOURCE: subwoofer doesn't work in stereo mode on kenwood
such is the case with sony receivers when stereo mode is used
SOURCE: i have a vr 309 kenwood reciever with a bad
Are you sure the VR309 is sending a signal out through the sub port? Attach one of your other speakers to it as a test (low volume). Then get back to us.
There are such things as user settings that affect this.
Under setup, is SUBW set to ON? We can't make assumptions.
