Question about Goodman CLJ30AR32 Air Conditioner
Do i need to turn a switch on or off on my goodman unit or the furnace? how do i prep for the summer with out calling a tech?
    Scholar:
  • 45 Answers
There are no switches other than the breaker and outdoor disconnect that need to be on. Change your filter in the furnace. I would take a hose to the outdoor coil on the condenser to clean out any dirt and leaves on the coils. Do not spray on high pressure. Just get a good light pressure and spreay from top to botton perpindicular to the fins and up at a 45 degree angle. Other than that, set the thermostat to cool and you should be good to go.
Posted on Jun 07, 2010
Goodman gmh95 furnace wont ignite
try the pressure switch you may be able to jump it out and see if it lights
Oct 01, 2016 | Goodman Heating & Cooling
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Goodman furnace fan cylcing
The fan switch is set to turn on at approximately 125 degrees and run until the heat exchanger temp drops to around 105 degrees. With age the sensitivity of this switch varies and summer heat can cause the switch to turn on if the outside temp is over 100 degrees. Only the fan is running, not the burner but you can shut off the power to the unit if this is an issue.
Aug 27, 2012 | Heating & Cooling
Goodman air conditioner not starting
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Sep 04, 2011 | Goodman CKL42AR42 Air Conditioner
Goodman dependable 92,7years old. Furnace works sometimes. Checked out by qualified technican. no problem found. Constant checks shows troubleshooting light blinks three (3) times. Help please. 3...
This indicates a open limit switch on the furnace, the heat exchanger is getting to hot therefore the limit switch is opening and not allowing the furnace to work properly. Did the techinician check the limit switch on the unit?
Dec 30, 2010 | Goodman GMS90703BXA Heater
I have a goodman gms9 gas fired furnace that does nothig.no led light,fans or anything.there is power to the unit and was working when shut down for the summer.
Look on the circuit board for a small fuse. Replace if necessary. take a small piece of wire and with the door safety switch taped down, jump out R and W terminals on circuit board. Unit should power up. You can also jump out R and G terminals and room air blower should turn on. If nothing, replace circuit board.
Nov 23, 2010 | Goodman GMS90703BXA Heater
I have a goodman 125-5 rev A furnace and it is showing a three blink error. what is this and can it be easily fixed or do i need to call a furnace tech. to look at it ?
FAN COVER SHOULD HAVE CODE LISTINGS .LOOK AT BOTH COVERS INSIDE AND OUT.  MANY CODES ARE PRINTED SOMEWHERE ON UNIT OR MANUAL. IF YOU TELL ME WHAT IT IS DOING OR NOT DOING I CAN HELP
Apr 19, 2010 | Goodman Heating & Cooling
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Goodman code problem three blinks
Same problem with 1 yr old Goodman. Checked entire exhaust and pressure switch. Inside fan, pressure switch hose clogged with crusty white gunk. Cleaned it & furnace fixed. I have no furnace repair experience, but love to "play MacGyver". Hopefully this could save someone a service call.
Sep 18, 2007 | Goodman GMS90703BXA Heater
Goodman CLJ30AR32 Air Conditioner Logo
56 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
