Question about Weber Summit S-470 Propane Grill
New webber will not start
Bought a new weber summit, but it will not light up...I have a new tank, no kinks...and no heat :_(...any ideas?
  • 494 Answers
Ok, let's tackle the obvious things first. New grill with new tank... so was the tank filled? Did they purge it before they filled it? Did you turn the tank valve on very slowly? Were all the grill knobs turned to off when you turned on the gas tank? Try closing the propane tank valve, disconnecting it and reconnecting it. Then very slowly turn it on and light one burner at a time at turn to low heat. Then light additional burners the same way and adjust flame as needed after all are lit. Hope this helps! Douglas
Posted on Jun 07, 2010
Just bought summit s 670 natural gas 89208 grill. Bought a display model because it was the last one they had. It was already assembled, so I took it home as is. Everything works great - except....the...
To determine if it is the switch, remove the wires from the back of the switch and touch them together, if the lights come on, it is the switch. You will have to contact Weber for a new switch.
Jul 17, 2011 | Weber Summit S-670 Gas Grill
Webber grill burners will not go beyond just starting and I used it a week ago and no problem. I put a new gas tank on and the same. Genesis silver unit
This should fixya up.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
Your grill should now heat normally
Nov 10, 2010 | Weber Genesis Silver B Grill
How to replace the carburetor with a high performance off road weber carburetor.
if you have a down draft carby, you can just buy an adaptor plate to suit a down draft webber if the webber doesn't just bolt on, or if you want to use side draft webbers, you'll need a new manifold too
Dec 24, 2009 | 1987 Nissan Sentra Wagon
Low flame
Try putting on a new regulator
Nov 23, 2009 | Weber Q Grill
Can't get a flame
Unscrew the fitting off the tank and make sure there isn't an extra washer in there. Sometimes when you get a tank there will be a washer inside it that has slid of the last guys POL(screw in hickey) With this extra washer, the POL isn't going in far enough to open the tank valve.
Sep 08, 2009 | Weber Summit E-620 Gas Grill
Cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
May 18, 2009 | Weber Baby Q Grill
Weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Mar 23, 2009 | Weber Genesis Silver C Grill
Weber Summit S-470  Propane Grill Logo
214 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
