Question about Kitchen Ranges
Gas oven will not light.
HOTPOINT RANGE model RGB628GEJ4AD. The gas oven will not light. The ignitor comes on and glows red but the gas never comes on.
  • Kitchen Ranges Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jun 07, 2010
Testimonial: "Thanks! I thought that it may be bad, but wasn't sure since it would glow red."
Hotpoint gas stove with electric ignition, model # RGB745GEV2WH -- oven will not come on -- I played with the knobs and got it to come on once tonight but can not duplicate that. Oven will simply not turn...
That's you ignitor. They get weak. If it has a glow that is dim orange that is a sign. Another sign of a weak glowbar is you can kick the oven and make her lite off. themobilian_467.jpg
Dec 17, 2010 | Hotpoint RGB535 Gas Kitchen Range
I have a Hotpoint range model RGB745BEH. The oven
Check the glowbar ignitor in the oven. If it does not glow or glows weakly replace it. If you are handy with a amp meter you can check the ignitor. If it shows 3 amps or less,replace the ignitor.
Sep 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hot Point stove oven and broiler won't turn on
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven burner won't light
You likely have a bad ignitor. It's like a mini element that heats up and then ignites the gas once the valve releases it. When the ignitor gets old it doesn't glow bight enough or draw enough amperage so the gas valve won't open. If you set bake and see a glow coming from under the plate in the oven but the burner never lights that's your culprit. They probably cost about $50-$80. Good luck!
Apr 28, 2009 | Hotpoint RGB745 Gas Kitchen Range
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Dec 20, 2008 | GE JGBP33SEHSS Stainless Steel Gas Kitchen...
New igniter, still won't work
Turn on oven. Ignitor should begin to glow. (if no glow after 30 seconds or so, check to make sure you have 120 volts to ignitor) Observe amperage draw using a clamp on amp meter. When amperage reaches 3.2 to 3.6 (for square syle ignitors) the oven safety valve should open, releasing gas and lighting the burner when the gas hits the red hot ignitor. For broiler, just substitute the word broiler for oven. Old ignitors get " weak " and may not draw enough amperage to allow safety valve to open. Also, voltage will affect the amperage draw, as lower voltage = lower amp draw.
Nov 06, 2008 | Hotpoint RGB745 Gas Kitchen Range
Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Dec 19, 2007 | Whirlpool SF310PEK Gas Kitchen Range
Hotpoint Gas oven doesn't light
Sounds like the oven ignitor is weak.  If everything else is working it must be a bad ignitor.  These are usually easy to replace and can expect to pay $70-$100 for the part.  Check to see if it glows when in bake mode first.  If it does then replace the ignitor.  You can look at the ignitor,  when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced.  Let me know if you have further questions.
Oct 12, 2007 | Hotpoint RGB790SEHSA Gas Kitchen Range
Kitchen Ranges Logo
276 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
