Question about Texas Instruments TI-83 Plus Calculator
When I press the "graph" key it doesn't show me the graph that it made. How do I reset the window parameters so I can see the graph?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You can press the WINDOW key (very top row, 2nd from the left) and change the parameters as desired.
You can reset everything to factory defaults by pressing 2ND MEM 7 2.
Posted on Jun 07, 2010
How to graph
How to graph a function
Look for a key labeled Y= ( the y= editor) and press it. Use the key pad to type in the right side of the function.
Press Graph to display the graph.
If drawing is out of range set the window parameters. Alternatively (if there is a zoom key) use it to select a ZoomIn, a ZoomOut , Zoom Standard.
Mar 23, 2012 | Sentry CA 756 Calculator
Only graph one function at a time
A) Before drawing function Y1=f(X), R1=F(Theta), (X1=f(T), Y1=f(T))
you should turn the statistical plots OFF.
To turn statistical plots off
  1. Press [2nd][Y=] to open the (STAT PLOT) menu.
  2. Select [4:PlotsOff] and
  3. Press [ENTER].
  4. Calculator displays Done
  5. Restart your graphs.
  6. Adjust the window dimensions if necessary or use the ZOOM function to have all graphs displayed.
B) If you cannot draw more than one function
Usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionalities from the native OS and you can only draw a single graph.
The reason is that dynamic graphing needs one or two parameters that can be changed during the graphing process and the graph redrawn with a new value of a parameter, and you end up with a family of curves differing one from the other by the values of one parameters. But since the calculator has space for 10 graphs at most, only one function can be highlighted.
To make a long story short, you must uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
  1. Press the [Apps] key.
  2. Scroll down or up to reach the Transfmapplication.
  3. Select it and press [ENTER].
  4. If that application was running you will see a new screen that tells you some thing like
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
    Graphing functionalities will revert to the native OS
Another potential culprit is the Inequalz App. You recognize that Inequalz is runnibg if the [ Y=] editor screen shows tabs at the bottom
To uninstall it, do as for the Transfm and select the option that will unload it from memory.
  1. Press [Apps]
  2. Select [ : Inequalz]
  3. Screen displays Inequal RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Press [2:Quit Inequal]
Mar 18, 2010 | Texas Instruments TI-84 Plus Calculator
The calculator doesnt graph two equation on the graph
  3. Press [ENTER].
To make a long story short, you must Uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
  1. Press [Apps]
  3. Screen displays INEQUAL RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Mar 17, 2010 | Texas Instruments TI-84 Plus Silver...
When I put an equation into y=, there are arrows to the left, I don't know why
A) Before drawing function Y1=f(X), R1=F(Theta), (X1=f(T0, Y1=f(T))
  3. Press [ENTER].
Usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionality from the native OS and you can only draw a single graph.
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
    Graphing functionality will revert to the native OS
Mar 17, 2010 | Texas Instruments TI-84 Plus Calculator
I cant graph more than one equation at a time, it only allows me to graph one Y value at a time.
  3. Press [ENTER].
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
Another potential culprit is the Inequalz App. You recognoze that Inequalz is runnibg if the [ Y=] editor screen shows tabs at the bottom
  1. Press [Apps]
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Feb 17, 2010 | Texas Instruments TI-84 Plus Calculator
Won't graph two functions
A) IF YOU GET AN ERROR MESSAGE,
it might be worthwhile to let us know its contents. If you do get a message ( INVALID DIM) you should turn the statistical plots OFF.
  3. Press [ENTER].
B) IF YOU DO NOT GET AN ERROR MESSAGE
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
Another potential culprit is the Inequalz App. To Uninstall it, do as for the Transfm and select the option that will unload it from memory.
Jan 25, 2010 | Texas Instruments TI-84 Plus Silver...
Graphing an equation
Press the Y= key to invoke the Y= editor. Enter in your equation.
Press the WINDOW key to set the window parameters.
Press the GRAPH key to have the calculator graph the equation.
For more details and options, see the "Function Graphing" chapter in the Guidebook.
Nov 11, 2009 | Office Equipment & Supplies
When i grath, there is message " invalid dim"
I think you are saying that when you graph, you get the message "invalid dim"
If you are trying to graph from the y= screen it may me that you have one of the plots on. If this is the case, look at the top of the y= screen. If plot 1, plot 2 or plot 3 has darkened box around it, the plot is on and you need to turn it off. Move your cursor on top of the one that is highlighted and press enter. You should now have the plot turned off and should be able to graph from the y= screen.
Another way to do this is to press 2nd key, plus key and then 7, and then 1 and then 2. This will reset your ram.
Hope this helps
Aug 31, 2009 | Texas Instruments TI-84 Plus Calculator
Graphing
Instruction book for this calculator is shocking for sure. It would take too long to explain fully, here is an example of plotting a simple Y= graph.
In main menu, when you first turn it on, press 1
This is normal calculator mode.
Press [shift] [menu] to get the set up parameters.
Scroll curser down one to Func Type, and select Y= if this is not already set, by pressing F1
Continue scrolling down to set Coord, Grid, Axes and Label functions. Turn these on or off as desired. Turn them all off for this example. F1 and F2 select On or Off here.
Press [exit]
Press [shift] F3 to access the V-window parameters. Here you set the size of the axis in the graph
Enter 0 for Xmin, 360 for Xmax, 0.1 for scale
Enter -1 for Ymin, 1 for Ymax, and 0.1 for scale
Press [exit]
Press [shift] F4 to enter graph plot mode (Sketch mode)
Press F1 then [EXE] to clear any previous graphs
Press F5 then F1 to select Y= type graph
Display should show Graph Y=
press [sin] [ X,0,T] (this key just under red alpha key) then [EXE]
Calculator should draw a sine wave, showing 1 complete wave
Try setting the parameters in Set up, Axes On, Label On etc to see the effect.
Hope this helps a little. Page 123 in book deals with graphing.
Mar 28, 2009 | Casio FX-9750GPlus Calculator
Problem using graphing on my casio
This calculator has so many options you can change, that it is possible one of them has been altered. Try pressing the master reset button at the back to re-set the calculator. Note that you will lose all your programs and data, so first copy out anything important. Also, set the xmin and xmax parameters to a higher value. To plot a sign wave, try xmin=-720, xmax=720, step=1, ymin=-1, ymax=1, step=.1 The step value won't change the appearance of the graph, just make it more chunky or fine. Use the equation y=sin x. This should draw a sign wave showing 4 complete waves. PS when you enter the X in the equations, you are pressing the X,0,T button, the one under the alpha key, aren't you? If you enter X using the x alpha key, it won't work. Also, to plot y=, make sure you change the func type parameter in the Set Up menu to y=. Hope this helps.
Oct 11, 2008 | Casio FX-9750GPlus Calculator
Texas Instruments TI-83 Plus Calculator Logo
64 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
