Washer leaks when on spin cycle
My Amana LW8253W leaks water at the bottom of the machine when it is on spin cycle. The drain hose from the back to the drain pipe is dry and fine. Is there a way to check the internal hoses to see if that is where the water is leaking.
  • 35 Answers
Drain is not working properly so that only spin is not starting
Posted on Jun 06, 2010
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
Amana washer model# LW8203L2 leaks from bottom when spinning.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jul 14, 2008 | Amana Washing Machines
Amana NTW5245TQ1 Topload washer....water draining out from basket...
Unfortuneately, I think you have two seperate problems. Fortuneately, this is easy to verify. As far as the not spinning, it is generally caused by loose hinge screws on the lid. There is a arm that sticks off the back of the hinge to press on your lid switch. If the screws are loose, the arm generally wont be able to press the switch. Just tightening ther screws on the right and left hand sides of the lid corrects this. You can verify this has corrected the problem by setting the washer to spin without adding any water. As far as the leaking. Well, there are multiple sources for this, but the most common is the water pump. To verify this, unplug your unit and pull it out from the wall. Tilt the top of the washer back towards the wall until it rests by itself at about a 45 degree angle. You are looking for a white peice of plastic towards the bottom front of the machine. There will be 2 black hoses going into it. run your finger across the front side of it feeling for bumps. You may have had something get lodged in there and poke a hole. If you can not find any moisture on the pump (yes it can leak from the hoses of back of the pump also)look for any signs of water having leaked. (you generally get water spots just like in your dishwasher when you don't use a rinse agent). If you still can't see anything, tilt the unit back forward and add 1 cup of water to the machine. Tilt it back again and see if it's leaking. Continue adding water until you can get your leak then trace the water back. However, if you do in fact have a bad pump, they are availible from local appliance parts suppliers (in the phone book) or on-line from the maunufacture. Any troubles or other problems? Drop me a line back. Otherwise,
Jul 10, 2008 | Amana NTW5400TQ Top Load Washer
Water leaking around machine
ck belt or replaced belt is designed to slip to a point if belt grabs too quickly the tub rpm come up to fast not giving tub time to drain down far enough to prvent climbing over the side also be sure drain hose is not plugged reducing water flow to drain
Jun 04, 2008 | Amana ALW880WH Top Load Washer
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Aug 04, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Washing Machines Logo
254 people viewed this question
Top Washing Machines Experts
