Question about LG 42PX5D 42 in. Plasma HDTV
Red picles areas
Smallish 2inch areas sometimes the picsles go red
  • 91 Answers
An aging plasma display and or the ysus.......zsus board set up alignments will cause this. If it is better warmed up........the ysus board may have some slow capacitors causing the adjustments to change causing mis firing pixels A qualified repair shop can check and hopefully repair this for $150 to $300 as long as the display itself is ok
Posted on Jun 06, 2010
Wont drain i think with the garbige disposal blocked it blocked the machine it is fisher picle
Disconnect the drain hose from under the sink, drain into bucket. If the dishwasher drains completely, check the hook up point under sink for obstructions.
Good Luck
Aug 27, 2011 | Dishwashers
Framers 702xp won't drive a nail more than an inch into wood and sometimes won't retract the pin all the way.
Before you use the tool put a few drops of oil into the air line input. The pin may be sticking. You could try spraying WD40 into the area where the nail comes out also.
Sometimes dirt can build up in the region that the pin slides in and other moving parts and cause them to stick so you may have to dismantle the gun to clean it. Spray WD40 on all moving parts before re-assembly.
Jul 14, 2011 | Senco 2K0013N FramePro 702XP 2Inch ...
Dryer wont heat. no igniter and no gas valve opening what can it be ?
Probably the igniter module. A smallish (3-4inches) rod of a ceramic like material which glows red hot to ignite the gas. The gas will not come on unless the sensor sees the glowing red hot ignitor.
So its possible the ignitor / flame sensor is bad, but its usually the ignitor itself. It is very delicate and easily broken. These can cost 10 bucks online, up to 60+ . Depends how soon you want it.
Pull the old one out and see the number on it. Plug that number into a Google search for dozons of ordering options. If it looks intact, look closely for a white looking spot in the grey area. That will be where its broke. Not repairable! Caution: DO NOT touch the grey part of the igniter - handle the igniter by its white part only
Here is one place to order from.
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Dryer&Brand=Whirlpool&PartType=Igniter
Try this site for more help http://www.repairclinic.com/Dryer-Troubleshooting
Jun 03, 2011 | Whirlpool Dryers
The last two red box blue ray videos I picked up won't play the sound on the feature movie. The pre-views, etc. play fine. My own old blue rays work fine. What could be the problem?
my two last rentals....red....& alpha and omega.. lots of picle drop out and refusted to play on both blue/ray6 vcr's
grrrrrrrr
thanks. carla prewitt
Dec 08, 2010 | Sharp BDHP20U Blu-Ray Player
How does the feul switch look like on a 2001 for explorer
It is about 1 inch by 2inch is has a red push button in the middle.
Hope this tip helps.
r/
David
Jan 25, 2010 | 2001 Ford Explorer Sport
Hello i have a samsung 47 inch hdtv model # Hcn4226W And i have a black area at the bottom of screen about 2inch high from the bottom of the scree..It double lettering on the screen and a little blurry . I...
Convergence issues again, try using the manual adjust with the remote.
you can only adjust the blue and red, if the green is wavy or the Red and Blue won't more then you will need the ICs or CBA changed again.
Jul 25, 2009 | Samsung Televison & Video
Cannot fax or copy message is check scanning area
Take out the cover that covers your recieving paper and look in there!U will c a smallish black handle with a green sticker on,pull it down gentle and push it up untill it clips into place!Good Luck!
May 12, 2009 | Office Equipment & Supplies
Bosch exxcel tumble dryer blowing cold air only
Remove smallish cover in center of back, 2 self tappers. Press RED reset button till it clicks, located just left of center at the back.
Oct 05, 2008 | Bosch Dryers
LG 42PX5D 42 in. Plasma HDTV Logo
120 people viewed this question
Computer Repairing
Computer Repairing
