Question about Cameras
My samsung l313 lens will not open or come out
The camera will not light up when turned on and the lens will not open or go out. the play button still works and it is possible to go through photos that i have already taken.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 06, 2010
Samsung S85 camera wont turn on. When the power button is pressed the green light flashes and the camera beeps three times than turns off. how do i fix it?
I quote the solution posted for another expert about this same problem...
My daughter has a Samsung S850, and returned from a weekend trip last night. She pressed the "Power" button and the blue light next to the button came on, as did the screen. The camera then gave a "buzzy beep" three times and shut-down. She decided the batteries were low and replaced them with ordinary AAA alkaline batteries, nothing special, and got the same result.
This morning I checked the voltage on the new and old batteries with a volt-ohm meter and found the old ones were low but the new ones were good.
I read this site and saw a comment that the camera worked after the lens was worked a little bit.
Upon a close look at the lens, I could see tiny grains of sand around the outside of the glass, so I got a wooden toothpick and gently worked the sand out with plenty of tapping on a solid surface to drop them from the area. I also worked the tip of a clean toothpick under what appears to be a soft rubber sealing ring on the outer surface of the glass.
After all this, when the "Power" button was pushed, the lens moved out and the screen lighted, and all the camera now seems to be working.
I should add that shortly after my daughter bought the camera, she lost some kind of metal or plastic ring from around the lens, and that left the "works" around the lens open to view: I can see two tiny screws the lens that are probably ordinarily covered.
Is the lens supposed to be covered by a curtain when power is off? From what I see, the lens is always uncovered. Maybe that lost ring held something else!
Its possible that
it needs repaired by samsung; You can follow the below link for tech support - http://www.samsung.com/uk/info/contactus.html
Hope this helps; send us you test comments.
Feb 26, 2011 | Samsung S85 Digital Camera
PLEASE COULD TELL ME WHERE I CAN GET A MANUAL FOR SAMSUNG L313
You should be able to download one from here:-
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=2702&prd_mdl_cd=EC-L313ZRBA%2FGB&prd_mdl_name=SAMSUNG+L313&srchword=SAMSUNG+L313
If that url doesn't work, start here and enter your camera details
http://www.samsung.com/uk/support/download/supportDownloadMain.do
Finally, just google Samsung L313 user manual.
Feb 05, 2011 | Cameras
Samsung L313 camera - lense is not retracting when off &...
You could return it (recommended) or try these: Fixing a Lens Error on a Digital Camera
Jan 07, 2010 | Samsung Digimax S500 Digital Camera
My samsung camera L313, Keep saying card Locked
  • connect it to the computer
  • look weather threis any hidden or zipped file or folder
  • if any unzip it or unhidden it
Nov 04, 2009 | Samsung L100 Digital Camera
Samsung L313 Charging Problem
it sounds like the battery is faulty. try a new one.
Aug 28, 2009 | Cameras
My samsung L830 camera has jammed with the lens open and
Just had this happen to my L100. First, take out the battery and wait a couple hours for everything to cool down and discharge. Then place the battery back in. Then plug the USB cord into the camera and PC. Then turn the camera on and it should be okay. Just worked for mine.
Jul 15, 2009 | Samsung Digimax L830 Digital Camera
My samsung l830 camera lens is stuck open and when i press the power button it beeps 3 times and remains blue then does nothing
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Jun 28, 2009 | Samsung Digimax L830 Digital Camera
Put camera on screen come on lens came out thwn power went off now power light wont stay on long enough lens wont go back in
maybe this works: turn your camera on in play mode (if you have play button press it to turn on camera) and if your camera hase a shoot-play switch select play mode and then turn your camera on.) repeat this until lens goes back. I hope this works...
Nov 01, 2008 | Samsung Cameras
3 beeps
had the same problem with my D53 eneded up buyin a new camera pulled the D53 out the other day was going to toss it then i noticed the lense was just a lil crooked i played with it a freed it up camera works great now
Sep 23, 2008 | Samsung Digimax D53 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Cameras Logo
228 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
