Question about Canon PowerShot SD1000 Digital Camera
Cannon sd1000 lcd screen black. Can review pictures, but cannot take new pictures.
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Jun 06, 2010
The screan is black i can take picturs fine and record but i when i go take a pic the screen is black until i review the pic. Its not the shutters because the screen isnt black when i have it on video...
The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to cannon service centre. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
Thank you
Jun 10, 2010 | Canon PowerShot SD1000 Digital Camera
I have a Cannon SD1000 stuck in revie mode. My daughter pulled it
If this was indeed dropped STOP! take it to a camera shop so they can do the repairs as you could damage other parts in the camera.
What could have happend when she dropped the camera the sensor inside got stuck into position to protect it from further damage. My advice is spend a couple bucks and take it in you be glad you did!
Sep 17, 2009 | Canon PowerShot SD1000 Digital Camera
My Cannon Powershot SD1000 LCD screen does not work. It will take pictures but will not let me change options, view the menu, or view images- past or present. Pressing the DISP button does nothing.
Has the screen been cracked/damaged? Was your camera dropped in any liquid? It's worth it to try having the LCD screen replaced, as it's quite affordable. If there is liquid damage near the LCD input inside the camera that would be another issue that would be solved by replacing those main boards.
In an ideal situation it would be just that the backlight cable wiggled itself out of its input (I'm assuming the screen doesn't light up anymore), which is something you could look at yourself if you're comfortable taking your camera apart. I wish you luck =)
Sep 08, 2009 | Canon PowerShot SD1000 Digital Camera
Black screen while shooting, but still taking pictures not black
Nonononooooo fotomohamed, he can review just taken pictures on the LCD. The screen is working.
Actually, it sounds like you just accidentally pressed the DISPLAY button on the back of your camera. This manually turns the screen on and off in picture taking mode to save batteries (you would then use optical viewfinder). Just press it once and it should turn back on.
Jun 19, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
I OWN A CANON POWERSHOT SD1000. THE DISPLAY SCREEN IS BLACK WHEN I TRY TO TAKE A PICTURE. HOWEVER PLAYBACK IS CLEARLY VISIBLE. IT IS ONLY WHEN I ENDEAVOUR TO TAKE A NEW PICTURE THAT THE SCREEN IS TOTALLY...
If you take a picture using the optical viewfinder, does the camera actually record the picture? If so, you may have the LCD turned off in the camera mode (there are three options: standard, detailed, and off). With the camera in the shooting mode, press the "DISP" button and see if the LCD turns on.
Aug 27, 2008 | Canon Cameras
Black screen, not capturing photos
have the same problem...
it happened about a month ago and i pressed the display button and it worked, but now that doesn't work either!
Jul 22, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
151 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
