Question about Brother MFC-8220 Fax
Copying leaves a black line on one side-2" from edge. Fax recipient states that their copy has the same. However, receiving a fax is normal. Do I need to clean the scanner? How? Procedure needed. Thanks.
  • jcaton_rep Jun 06, 2010
    Just a thought--how come the received faxes are ok?
    President:
  • 3,085 Answers
If the scanner glass is not dirty, then an element in the scanner block is burned out. Not worth repairing
Posted on Jun 06, 2010
Testimonial: "Never would have figured that out."
  • Leroy Elliott
    Leroy Elliott Jun 06, 2010
    Printed stuff comes from the laser unit and doesn't use the scanner.
    Sending a fax and copying use the scanner.
I keep getting a black line about 2 inches along the right side of the paper if copying as well any faxes sent are also getting that blac line. Brother fax machine intel 4750e
Well you said the Lines are present when you are copying and when you are sending from the fax unit. Copying and sending functions both uses the scanning unit. What you lift open the document feeder for original documents. In there you should see rollers and a glass. clean this glass with cotton swab and alcohol for left to right the entire glass. Close the unit and try copying or sending, documents should now be clean.
Apr 04, 2011 | Office Equipment & Supplies
When faxing a paper and the recipient receives the fax, their copy has a wide black lines down the side....if we make a copy, it has wide black lines down the side....we have replaced the drummer we've...
FIRST I would check the scanner glass again you can test it by asking for a report to be printed..ie tx REPORT.. if this dowsnt have a line on it the problem is either the scanner glass or at worst the scanner unit it self.. I would double check the glass.. get a soft cloth and some glass cleaner on it and give the glass a good rub over. do you have the lines on incoming faxes .. if not the glass or scanner unit is the def area to be looking at, Luck A
Aug 27, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Winfax Basic
If you have the fax # correct, than it is the responsibility of the fax recipient to correct the situation. You cannot make a parametrical changes to someone elses fax machine. Thank you, Dana
Jan 18, 2010 | Symantec WinFax Pro for PC
Black page when copying and sending faxes.
You most likely have a bad SCANNER BLOCK. Not good!
Dec 23, 2008 | Brother IntelliFAX 4100 Laser Fax
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Dec 22, 2008 | HP LaserJet 3050 All-In-One Printer
1 inch black stripe down edge of page
can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Nov 21, 2008 | Panasonic DP-150FX Laser Printer
Hello, I have a little used 18 mth old Sharp FO P610 fax machine. It receives fine but when sending the recipient receives 'black all over' pages. I have tried disconnecting the unit for an hour and...
Try just making a copy and see if you have the black lines on your copy (most fax machines have a basic copy function if it is you have dirty scan glass and on these small machines it is a real hassle to get too and clean Try Canned Air. If no black line on your copy it may be the recipients machine.
Aug 12, 2008 | Sharp Office Equipment & Supplies
Recipient receives a black page
What happens when you make a copy on your machine?
Dec 11, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
Brother MFC-8220 Fax Logo
367 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
