Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Have not started saw in 4 mos. Now cannot start. Replaced fuel and still won't start.
  • 12 Answers
Did the saw sit for this time with gas in it? If so, the gas in the carb has probably turned to shellac. Take the top cover off, remove the air filter, open the carb butterfly and spray some carb cleaner in it. Wait 24 hours and try to get it to fire. While you're waiting, check the plug for fouling. If it still won't fire, give it a small shot of starter fluid.
Posted on Jun 13, 2010
Replaced all fuel lines and pickup fuel filter. but won't stay running without choke.
Take the carburetor off and clean it and check and replace any air filters you may have. Can't say that this will fix it ,but it is a starting point for you. Hope it works and good luck.
Dec 01, 2012 | Poulan P3416 16Inch 34cc 2Cycle Gas...
WON'T START
If the fuel line and filter are in good shape then it will probably need the carb rebuilt or replaced. Check the fuel line first. The ethanol in gas eats these up badly.
Aug 14, 2012 | Saws
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Ran out of gas-truck won't start-replaced fuel
you probably have air in the lines, if you have a carb, spray some quick start into the carb and turn it over, if it starts and then dies when the starting fluid has run out, you probably need a fuel pump, since the running of the car should have blown out any air that was in the line, If your car is fuel injected, loosen the bolt cap at the end of the injector line that supplies the fuel,, and tap the key once,, ( don't start it,, ) just turn the key on and off 3 or 4 times, this should blow fuel out of that loose bolt head, if it does your getting fuel, if not, back to the fuel pump, also you can check this link, http://www.aa1car.com/library/us1296.htm
Jul 24, 2011 | Chevrolet Suburban 1500 Cars & Trucks
My chain saw will not start model #3314 14 inch I followed the directons on saw yet it will not start I also have the manual and followed the directions
How many hours on the unit?
Does it have spark?
Is it getting fuel?
Check the compression. If it has low compression it won't start.
Jul 05, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Replaced engine 2 mos ago. Shuts off, start back
fuel pump is probably in need of replacement. big problem with grands they will work intermittently or overheat an short out. make sure gas tank is low before replacing it, please also replace fuel filter (bosch brand fuel pump better than airtex) i hope this helps you
Sep 04, 2009 | 1999 Jeep Grand Cherokee
Homelite xl-175 chain saw no prime
As long as the line fits tight so its not sucking air you should be ok.. try changing out the plug if its old. Clean out the air filter too.. But the line should be ok as long as its tight..
Jul 10, 2009 | Garden
Wont start after 6 mos. I changed the spark plug, drained & added fresh gas, checked the fuel filter... Kicks over fine. Ran for 4 seconds, then it died. Always ran & started great before.
With a new plug and fresh gas it should start. Check to make sure there isn't a kill switch turned off or that the gas petcock from the tank to the carb is on.
How did you check the fuel filter? Disconnecting it from the fuel line that goes to the carb is the best way, making sure the gas is turned on under the tank. Bleed off a little gas into a can or something just to make sure the filter isn't plugged.
The last thing I'd do is take off the air filter and spray a little starting fluid in the carb. It may start and run several times if there is old gas in there somewhere. Remember the bowl on the carb is probably still full of old gas. After some fresh fuel reaches the plug it should start and continue to run.
(You might drain the bowl on the carb of ols gas before you go any further)
Sirwriter
May 22, 2009 | 2006 Honda Civic Hybrid
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
171 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
