Question about Brother MFC-5440CN All-In-One InkJet Printer
I get a message on the LED saying, "Unable to Clean". This error message, per the manual, suggests it could be a mechanical issue. I've checked for paper jams, paper clips and odd scraps under the printer head, etc. The head is to the far right and instructions say, "Don't force if to the far right". This sounds like a mechanical problem. It's been a great printer for the price, but probably not worth investing in a local service center (spent about $150.00 when new). Any ideas on how to repair?
  • Robert Yale Jun 09, 2010
    It gave me a tip on where to look further. I went on to another site and followed a thread of several users who discovered the problem to be an overloaded ink resevoir. I checked with a local Brother service tech who confirmed that "Unable to Clean" and error code 46 refer to this issue.
  • 516 Answers
Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
Posted on Jun 06, 2010
  • Robert Yale Jun 06, 2010
    Solution:
    Machine off On/Off button doesn't seem to be working. I have to pull the plug to shut off all lights
    Switch on the machine while holding down the "menu"button until all the leds are flashing on/off. Now you are in "maintenance" mode. When I switched on and held down the menu button it never came to maintenance
    I get "Machine Error 46"
    Press 80 I did try 80
    Press the "mono start" button several times until you see "purge: xxxx" I did not get the purge indicator
    Press "2783" in order to reset the purge counter. You will see: "purge:0000" I tried the 2783, did not get the purge counter
    Press "99" to exit the maintenance mode.
    After the steps above, which I realize did not go according to your message, it came back to the error message saying "Unable to clean".
Unable to clean
If the message is 'Unable to Clean: Error 46' I would recommend checking out this video.
If however you are receiving 'Error 4F' this is a mechanical issue and I would advise getting in touch with a printer technician or Brother themselves.
Aug 07, 2013 | Brother DCP 115C All-In-One InkJet Printer
My brother 5840CN. lit says unable to print. the manual says to take the jam out - there was no jam. Turn it off, then on. i did that. It still says unable to print, look at troubleshooting page
errr.....No, no it does not. The Manual says that "unable to clean" means one of two things.....
1. The MFC has a mechanical problem.-OR-2. A foreign obstacle, such as a clip or ripped paper, is in the MFC.
but regardless, I don't believe it *IS* a 'cleaning' problem per se.Try resetting the power purge counter.
Press menu > Mono Start > 4x Arrow up after another. All lights will flash.
1. Power clean - Press 7>6>4 >Mono? Start.
2. Power Purge: 7>6 >3 >Mono Start.
Press 9>9 to exit maintenance mode. Run a print quality test print.
http://www.brotherprinterrepair.com/cleaning-a-brother-mfc-420cn-printer-head/
Tallon41
Sep 16, 2012 | Brother MFC-5840CN All-In-One InkJet...
Error message UNABLE TO CLEAN see troubleshooting in user's guide
If you see a message that says UNABLE TO CLEAN, it usually means there is something wrong in the printing mechanism. More than likely it has a bad printhead.
Oct 08, 2009 | Brother Office Equipment & Supplies
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error : Unable to clean
Unable to clean means that the waste-ink "sponge" is full. If you've already checked for small paper part (which is very unlikely to cause this error message), the error is mechanical. Unfortunately, that's not something us users can change, but the machine would require to be sent to service. So if your machine is not within warranty, I'd doubt it'll be worth the service cost.
Jun 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean-need trouble shooting guide
I am having usual problem of unable to clean (Brother MFC-5440CN). I have looked for any strange object but can't find any. Could this be amechanical problem and what is solution?
May 27, 2009 | Brother MFC-5440CN All-In-One InkJet...
Error 46 and says unable to clean. can u help me plz
According to the manual, the unable to clean error means a mechanical problem or a foreign object in the machine: Open the scanner cover and remove
any foreign obstacles inside the
machine. If the error message
continues, disconnect the machine
from the power source for several
minutes then reconnect it.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002010/BH3eDCPWLAN_UkEngUsr.pdf
Apr 24, 2009 | Brother DCP-340CW All-In-One InkJet...
Printer has unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
Then with the power on, pull the plug from the wall for several minutes. The plug it in and power the unit up.
Here is the manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 18, 2008 | Brother MFC 420CN All-In-One InkJet...
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Cleaning troubleshoot needed
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model. This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue. 1. Check for foreign objects, such as a clip or ripped paper, inside the machine. Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. 2. If the error continues to appear, the machine may have a mechanical problem. If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Jul 28, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
71 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
