Question about Whirlpool DU1055XTSQ Built-in Dishwasher
Dishwasher is not cleaning and soap is remaining in dispenser after the cycles are done
    Genius:
  • 1,036 Answers
This sounds like the dispenser is at fault. It could be siezed up, a fault in the unit or a broken cable to it.
Only way to check is to disconnect the unit and remove the door panel. Check with multimeter first, then see if operation is easy. Understand how a "wax motor" works if it uses one of these before replacing parts.
Posted on Jun 06, 2010
Whirlpool dishwasher when operating does not open the soap dispenser and it remains open all the dishwasher operating cycle.
Dear Jesus,
Often water and/or soap gets inside the mechanism and causes the soap door to stop working.
The solution will be to take the door all apart and clean it all out.
Having done so a few times, I might suggest you know I have never been able to get one to work after taking it all apart.
God bless your efforts.
Jan 24, 2017 | Whirlpool Dishwashers
Soap dispenser opens but soap remains at the bottom tray after cleaning cycle
The sprayer arms are not able to rotate freely and clean out the dispenser cup.
Sep 02, 2012 | Frigidaire Professional Series 24 in....
The soap remains inside the dispenser, thus door opens up, but soap remains inside....just drips down the door.
What you have is a faulty cycle timer. Replace this and your dispenser will dispense the soap when prompted.
Mar 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Hi. My problem is with my dishwasher detergent dispenser. It does open (at least it is open at completion of cleaning cycle), appears to deliver soap to dishes (as they appear clean), however, from the...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 14, 2011 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Washer will not dispense soap from dispenser.
make sure that the soap dispenser if clean and free of residue build up. if this is clean you need to replace the dispencer
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Soap dispenser problem?
Check the water supply. Start cycle then open the door after it fills and check water level and spray action. If everything is soaking wet, there is probablyl a pizza pan blocking the soap tray.
Jan 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Soap doesn't empty from dispenser
Assuming you are using the correct detergent powder, check if the dishes are remaining dirty.
The water from the impeller may not be rushing up enough due to blockage or limited movement of impeller arm. Follow the insructions to clean the impeller, filter etc or check base of drawer for obstructions to impeller arm.
Dec 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Dishwasher soap remains in the soap dispenser following the complete cycle. I have had the washer for a year and a half. The first year, no soap remained in the dispenser. Now about 1/8th of the soap...
Try cleaning the soap dispenser with white vinegar so that it is free of all detergent, then try using about 1/4 less detergent than you have been to see if you still have any remaining in the dispenser. Also, make sure your drain filter is free of all sediment so that the system can pump the water out freely. Lastly, if you are still getting some soap remains, then try using a sanitary setting that uses the hottest water and see if the excess soap is properly dispensed. Your water temp may not be getting hot enough so this test should help identofy the solution. Hope this helps !
Aug 20, 2008 | Whirlpool Dishwashers
Whirlpool DU1055XTSQ Built-in Dishwasher Logo
107 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
