Two loads back dishwasher starting buzzing while washing. (Service tec out after 15 min taking bottom panel off looking under machine, said bad motor and pump repair 300 to $400 for parts) we said no thank you.
On third load buzzing is lower but it is not changing cycles and is repeating wash cycle.
There is a small motor that advances the program on simpler types of machine. This is a mains-motor that needs a run capacitor to work. If this small capacitor is defective, it will cause the motor to buzz instead of rotating. If you are able to locate it and solder - in an identical component, it will likely solve the problem.
See if you can identify which motor is at fault to check the capacitor on it. These are cheap components - $1 or so.
