Question about Asrock ConRoeXFire-eSATA2 (CONROEXFIREESATA2R2) Motherboard
Booting this is my second time i face this problem, the first time i had to change my samsung 1TB hard disk to make it work. I had reinstalled Win 7 Ultimate x64 (7600) to my (only one) Western Digital caviar 2TB hard disk, during the installation i deleted the first partition 97 GB & second 100MB system and teft the third partition and created the first 97 partition + 100 MB again , then procced with the installation to the end , then my pc restarted the pc but could not boot instead i got this, a screen with conRoexfire - esata Bios p2.00 cpu intel core 2 cpu 6400 2.31 GHZ speed 2.13 GHZ press F2 to run setup press F11 for boot menu Dual-channel memory mode 2048MB ok Auto Detecting Pri master IDE hard disk Auto Detecting 3rg master Atapi CDROM Pri master : WDC WD20EARS - 00S8B1 80.00 A80 Ultra DMA mode -5,S.M.A.R.T. capable and status ok i tryed F2 and got : entering setup and nothing happens . Else nothing is working, Then i had to go back to my old hard disk ( not SATA , somthing with pci card i maybe scsi Total 80 GB ) with Xp and the system is runing now , then i tryed to install win 7 with this Hdd but it did not see it during the installation , I installed the latest Bios from Asrock site and know it is p2 , and then i installe the Sata Hdd and had the same problem again . Can you please advise me what to do any thing comes from you would be most appreciated Thanks
    President:
  • 2,351 Answers
When it come to deleting partitions or adding partitions I suggest you download WD's Data Lifeguard Tools. WD's User manual;
http://www.wdc.com/en/library/other/2779-001005.pdf
The object is to setup you're partitions in DOS mode by creating either a bootable CD or a bootable floppy disk. Using windows is not always the best way.
Same for you're Samsung drive, ES-Tool;
http://www.samsung.com/global/business/hdd/support/utilities/ES_Tool.html
Once completed installing you're operating system should be simple. Be sure to check the boot order in you're bios before loading you're OS.
Mike
Posted on Jun 07, 2010
Trying to put win 7 on hard drive says no bootable device insert boot disk and press any key put in boot disk and nothing
if you have win 7 on a disc and you want to put it on the hard drive , try this
on start up hold down alt+ delete to get into bios
change the boot up from hard drive to cd as primary start up boot up
put the disc in a cd and close it down
restart and the pc should then boot from the disc in the cd drive
you should be able also to simply put the disc in the cd, go to computer , click on the cd drive and run and that should put the win 7 on the hard drive
talk with a computer shop for other ideas as to how to do it if that doesn't work
Nov 29, 2016 | Cell Phones
Tip
Restore win 7 from system image on toshiba portage m200
This should apply to other brands and models...
the original problem: bad hard disk, need to restore from win 7 image disks however The portage m200 lacks an optical drive and cannot be booted from usb (only options are to boot from LAN or from a specially created SD card).
Solution:
you will need a second pc that can boot from an on board or peripheral optical drive. Swap the second pc's hard drive for the one that you are restoring. Now boot the second pc from the restore disk and follow the onscreen instructions. Once completed the pc will try to reboot and you will get an error about how windows couldn't repair start-up. Now power down and swap the hard drive back to the portage. You should now be up and running, much easier than trying to create a boot-able sd image or boot from a PXE server.
on Oct 10, 2010 | Toshiba Portege M200 Tablet PC
Having with my dell inspiron window 7 laptop(hard drive/corrupt registry) how do I restore it too factory setting?
If you have tried every system restore point, that is when you open system restore you checked show more points, and have tried all of them, then you must reinstall the OS.
If you don't have a windows disk, you can download win 7, it is legal to download and use for 30 day's, but then you are suppose to register it.
If you download it, you should check the hash number, but it's not a second deal, you would need to read about how to do this.
I will post a link for win 7 downloads, for the most part I can say these are not touched, they are ok.
These are ISO files, so you need a software like free ISO burner, this will open and burn the file to a DVD disk, now you have a win 7 install disk.
You can also use the win 7 disk to repair windows, so if you do burn it, try repairing windows with it first.
Here is a link if you need to see how to install win 7, with pictures.
http://www.buildeasypc.com/sw/windows_7/install_windows_7.htm
Here is where you can get win 7, pick the version you have now because the serial key only works for that version you have now.
http://malwaretips.com/blogs/download-windows-7-sp1-iso/
Apr 12, 2013 | Dell Inspiron Computers & Internet
Diagram of USB and hard drive slots on H-RS880-uATX (Aloe)
the best way to find out the connection order is in the bios. sadly i dont have your exact mother board on hand to look at the bios and tell you exactly where in the bios it is. i do not know how to map usb slots from my own experience maybe someone else knows a sure fire way. you can get an idea from device manager and plugging in usb devices into slots one at a time and make your own map based on which slots are changed in device manager.
Sep 10, 2012 | Foxconn H-rs880-uatx Hp Aloe Motherboard...
I bought a new Western Digital Caviar Blue 1TB SATA 3.5" Desktop Hard Drive 6Gb/s It dosent work for me, I can see it in the CMOS Setup under Sata 1. My MSI K9N8PGM2 motherboard only support...
you need hard drive formatter this is in disk manager, windows 7 press windows key and then X go to disc manager, in the menu you will find your hard drive and make sure its the right one. and click on format drive, on the folder of the drive.
Jul 08, 2017 | Western Digital Caviar Blue 1TB SATA 3.5"...
My Samsung HX-MU010EA/G2 1TB portable hard drive is not working. It is not being recognised by my computer all of a sudden after about 6 weeks of use. The blue light flashes quickly but does not give...
Have a look in disk management if on win 7 or vista just type in "disk Management" in your search bar after clicking start button and see if it shows up there. If not try plugging into another computer and see what happens. If still no good you say only 6 weeks it should be guaranteed. If your data is important to you never trust just 1 source of backup maybe start copying to DVD's also. Good luck with it from Scott
May 17, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
It wont boot, but read corectly at bios screen, but when i try to reinstall an OS such as linux ubuntu, win xp and win 7, it says that cant find any HDD..@ linux Os, its readable but when we try to format...
I would recommend using a boot disk and run chkdsk (windows boot disk) or fsck (linux) This will help fix bad sectors if you use the correct options. USe the "/?" in windows for help and "man fsck" in linux.
Good luck and let me know how it goes.
Joe
Feb 15, 2011 | Fujitsu - MJA2160BH 160 GB SATA Hard Drive
When i connect my samsung CD ROM drive (CD-RW/DVD DRIVE SM-332) hard disk doesn't work and it shows an error hard disk drive Emmett failure.but when i disconnect my samsung CD ROM drive (CD-RW/DVD DRIVE...
You will have to chnage the Boot Priority
Go to BOIS setup coniguration option by hiting F2 , F12 or Del key when staring the system
Change the priority to CD ROM as first priority and insert the Windows Disk and reboot the system to Run the Win XP setup
Aug 01, 2010 | Samsung DELL CD-RW/DVD DRIVE SM-332 BLACK...
My computer can't detect my external harddrive..
connect the drive, go to disk management and check if the drive is there. change the disk letter.
Jun 23, 2009 | Seagate FreeAgent Pro 1TB External USB...
Asrock ConRoeXFire-eSATA2 (CONROEXFIREESATA2R2) Motherboard Logo
515 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
