Question about Car Audio & Video
Steering wheel put it back togetther - Car Audio & Video
  • 6,993 Answers
please can you rephrase your question? I don't really understand the question.
What is your steering wheel putting together?
I look forward to your reply,
bye for now.
Posted on Jun 06, 2010
Steering column won't unlock
The front wheels are at a angle putting pressure on the steering lock , rock the steering wheel from side to side while turning the key.
Mar 27, 2015 | 1996 Toyota Camry
REPLACED STEERING GEAR BOX IN 2003 CADILLAC ESCALADE NOW WHEEL IS OFF CENTERED
IF you have a rack and pinion steering pull the steering shaft of the pinion splines and centre the wheels . Centre the wheel and put the steering shaft back on the splines. If it is master splined then centre the steering wheel and adjust each side tie rod until the wheels are centred . (one in -other out ). Remember that when the wheels are straight ahead then the steering wheel will be slightly to the left (USA) to compensate for the camber of the road.. IF a steering box pull the pitman arm off --centre the wheels and the steering wheel and refit the pitman arm
Mar 02, 2014 | Cadillac Cars & Trucks
1989golf 1.8 gti 16 valve mk 2have had steering wheel off put it back steering lock wont work and horn goes off when tightenig nut
Hi. It sounds like the steering lock has not been put back into position properly. This would need reassembly.
Feb 11, 2014 | 1988 Volkswagen Golf
Steering wheel not centered
I'm a mechanic and have pulled alot of steering wheels off. There are several groves on the shaft that the steering wheel fits over allowing it to be put on in several different spots. There is no way it was put on in the right spot. Take it back and tell him it wasn't like that before and he needs to remove it and set it back on straight. If they won't do it then tell them you will take it to another shop and post reviews on line about there service.
Sep 29, 2017 | Cars & Trucks
My key won't turn and my steering wheel is locked.
push your foot on the brake pedal and try to put it into park, then turn steering wheel at same time as you try to turn key
Apr 02, 2013 | Cars & Trucks
00/01 Pontiac Bonneville. How do we get off the steering wheel?
Get a repair manual such as Haynes or Chiltons at a auto parts store to walk you through. Once you get the horn button off you will need a steering wheel puller. They sell them too.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 23, 2010 | 2001 Pontiac Bonneville
How do you move the steering wheel a couple of splines on a 2003 Hyundai Tiburon? It`s not out of alignment. It`s a salvage vehicle and the steering rack must be slightly left of center.
You have to pull the steering wheel to get it straightened out. Look in the back of the wheel, 2 screws? Pull the air bag, remove the nut to the top of the threads, pound on the nut, not the threads with a brass hammer, it should pop off, if it doesn't, you have to get a wheel puller on there, pop the wheel, make sure the front wheels are straight, then put it back on straight, tighten it up and put the airbag back on. Hope this helps.
Feb 28, 2010 | 2003 Hyundai Tiburon
Hi, got a 1988 chevy blazer, can't get the steering column back together, any suggestions?
hello, usually when pulling steering wheel u need to rent a steering wheel puller, the spring that is inside is hard to push in. once you get off it is almost impossible to put back on with out puller, you have to push spring in then put the nut back on and then the clip, that keeps steering wheel from coming off
Feb 06, 2010 | 1988 Chevrolet Blazer
I cannot figure out how to pull the steering wheel off of my 96 honda accord
Read this carefully, in total, before you begin.
With car wheels aimed straight ahead, disconnect the neg. battery terminal (if you have an anti-theft radio, make sure you have the code, because you will need it.)
Wait three minutes before proceeding to allow the airbag’s backup power supply to be depleted.
Remove the access plate from the lower steering column cover and remove the short connector from the access plate (the short connector is stowed on the inside of the access plate. It is a little device that is used especially for this purpose)
Unplug the airbag module-to-cable reel connector (yellow) and plug the short connector into the airbag module side of this connection to disable the airbag.
Remove the access panels from each side of the back of the steering wheel cover, then remove both of the torx screws (you’ll need a torx screwdriver) that retain the airbag module to the steering wheel.
Pull the module off the steering wheel and CAREFULLY set it aside with the trim side facing up.
Unplug the electrical connector for the horn, and, if you have it, for the cruise control.
Remove the steering wheel retaining nut. Paint or scribe a mark indicating the relationship of the steering wheel hub to the steering shaft.
Remove the steering wheel with a steering wheel puller. DO NOT turn the steering shaft while the steering wheel is removed. If you do so, the airbag reel could be damaged.
Reinstallation is the reverse of the removal, making sure the cable reel is centered with the car wheels straight ahead (if you haven't moved the shaft, that should not be a problem), and making sure that the locating pins on the steering column engage the holes in the back of the steering wheel. Put the nut back. Torque it (36 ft. lbs). Reconnect horn and cruise control. Replace airbag, tighten torx screws. Reconnect airbag and put short connector back in access plate. Reconnect neg. battery cable.
Hope this helps you.
Feb 05, 2010 | 1996 Honda Accord
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
