Question about Ryobi 30cc 17" String Trimmer Zrry30530 Wcurve Shaft
Changed spark plug, but still stalling after 1/2 minute
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Simple answer get rid of the machine
Posted on Jul 27, 2010
Chevy venture stalled
Compression, spark , timing , fuel for any engine to run. Don't forget a stopped up catalytic convertor will have the same effect as you described. Backfiring of course is fouled plugs, bad plug wires, look for arcing from wires when it is dark outside. If it has a distributor check for cracked cap, had my 91 GMC start backfiring then die due to ignition module inside distributor going bad. It would start back up after it cooled for about 10 minutes.
May 16, 2017 | Cars & Trucks
My 1988 jeep grand cherokee stalls after running for a short while then wont restart for at least 15 minutes
I saw what you replaced, didn't see any testing?
The basics, if it cranks good but won't start, have a helper crank it while you check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure and fuel injector pulse.
How long since a tune-up? Any applicable trouble codes?
Aug 04, 2017 | Cars & Trucks
2006 aveo stalling and no power. # 1 cylinder not firing properly. Start it again and for a couple of minutes starts running rough again. changed plug and checked spark, both ok. ses codes p0106 the first...
code p 0106/7 refers to manifold absolute pressure (MAP) and BARO pressure sensor --range /performance and low input problems ===causes wiring ---MAP sensor---Baro sensor --wiring short to ground ---ECM
no 1 not firing would be a problem injector
Oct 29, 2017 | 2006 Chevrolet Aveo
1988 3.8 olds cutlass Ciera stalls, no spark until it cools down
Check the prrimary and secondary resistance on your coil. Also check the resistance of the plug wires and plug gap.
Aug 12, 2009 | 1988 Oldsmobile Cutlass Ciera
1990 Buick Century 3.3L Check Engine Light comes on, stalls.
Need to check for fault codes. Possibly a faulty sensor causing the fuel system to run rich or lean.
Mar 27, 2009 | 1990 Buick Century
Ryobi 30cc 17" String Trimmer Zrry30530 Wcurve Shaft Logo
154 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
