Not able to use my printer,message pops up say current user has no permission to use. Enen though I'm running as administer, unistalled then reinstalled now it can't configured product. only had it since Feb 08
    Genius:
  • 2,785 Answers
Please scan your pc for viruses in safemode by updating your viruse defination(plz diable the system restore)
post your findings
Posted on Apr 10, 2008
I can not download this product because I'm not the administer so I need to change the e-mail.
Use "Save As", and select "Desktop" as the destination.
A "user" account always does have permission to download a file onto the "Desktop" folder.
Aug 21, 2015 | Computers & Internet
I tried to change permissions on my hard drive and now I am unable to have access to anything other than just opening programs and folders.
Enable the administrator account, login as administrator and select your regular users folder and assign your regular user as owner.
Enable admin Open a cmd prompt, run as adminif in win vista/7 type without quotes "net use administrator /active:yes" Log out of current user and login as administrator
Now you should have permission to set permissions to your other users folder. Set ownership to originsl user.
Comment if you get stuck or need more help
Aug 05, 2011 | Acer Aspire 5050-3242 Notebook
I already asked aquestion but solution didn't work. I got a computerfrom my sister-n-law and everything is setup with a user name and I tried to delete user name and now com says............. User's...
Boot into recovery mode from GRUB menu, at the prompt, change user password again to something easy to remember.
passwd user
Then, change the ownership/permission of /home/user/.dmrc to you won't get that error/ignore message the next time you log in.
chown user:user /home/user/.dmrc
chmod 644 /home/user/.dmrc
Now reboot.
shutdown -r now
Mar 05, 2011 | MSI Wind U100-030US Laptop
I've been getting pop-up windows that say I am prevented from opening or changing documents/files due to lack of authorization or permission. I am the owner of and only person using this computer. How can...
I am not sure if the documents or files that you are opening or changing are from attachments sent to you via email or not, but I can suggest that you can try this step:
Right click on one of the affected files and select Get Info.
This will open a long narrow box providing detailed information of the document.
Now look at the bottom of the window under Sharing & Permissions
Click the padlock and enter your User Admin password when the pop up window appears.
This will allow you access to changing the current permissions of this document.
Make sure you see permissions for "Read and Write" attached to your user name.
If you do, then go ahead and close this window. However, if you see only Read permissions attached to your user, then change that to Read and Write.
Once you have done this, close this Get Info window.
Try to launch that affect document to see if it opens now. If it does then this may be a permissions issue that is affecting your documents and files.
Whether you can or not, I would still recommend you still run this procedure below in order to try and fix this permissions issue.
Now run Disk Utility to repair all permissions on your Mac OS X volume.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} -RUN DISK UTILITY-
Go to Finder Menu bar
• Click Go > Utilities > Disk Utility and open up Disk Utility app.
• Click on Macintosh HD volume (or on the name you have changed this volume to.)
• Select "Repair Disk Permissions"
**Let Disk Utilities run this repair permissions until completion
Once Disk Utility is complete and there are no errors in red in the completion summary (if there are errors listed in red, re-run Disk Utility to see if those error will clear- if they don't reply back to this post right away and let me know what the exact error message is), quit Disk Utility.
• Now attempt once again to access the affected documents and files and see if you are able to access these items now.
I hope this helps.
Regards,
-Mactechtrainer
Feb 06, 2010 | Apple MacBook Pro with 17" Display
Problem with installation of Cannon Pixma mp240
chosse the logon option with administrator rights and also when you running the setup file reight click on it and choose the option run as administrator and follow the instrcuction.
Jan 20, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Though i know i have done backup on acer aspire e571
Your computer operating system is corrupt. Or maybe there is virus on your system that has made it corrupt.
Do you have any anti virus on your system? I will recommend that you try Avira Anti-virus. After you have installed the anti virus, use it to scan your system thoroughly and see if problem will persist.
If problem persist, then you will have to run the recover manager on your system. The recovery manager will help you repair and put your windows back to order, that is, to its factory default state.
Before you carry out the system restore, make sure you backup all your important files.
To do the system restore, click start menu, click all programs, look out for "Back up and recovery manager, click it and follow instructions.
I wish you the best.
Dec 18, 2009 | Acer Aspire 4315 Notebook
I have a problem with a printer which is connected locally to a pc (comp1) on the network. I can access it from one pc but can not access from 3 other pc. I have three printers locally connected and...
Hi Shueb,
First off, I assume if your running a network, you'd have a server based product running. If so, I would have the server manage the printer as a shared printer. This can be accomplished by setting up the share either in your management console or your active directory. Then the server will administer the rights to the printer. If your running a network with just workgroups, then you will have to right click the printer and go to share and security. From there go to permissions and make sure that the users on those machines have permission to access it.
A real easy way to connect a shared printer on a network is to browse through the entire network icon, and click on the machine that is sharing that printer, and when you see the printer right click it, and go to connect printer, and that's it. As long as you've got all the drivers for all the different OS's on the differnent machine, it will install the driver and give you access.
Good Luck,
Mark
Jan 15, 2009 | Computers & Internet
Want to turn off Vista permissions
Open up Control Panel, and type in user account into the search box. You'll see the link for "Turn User Account Control (UAC) on or off". Click it. Uncheck the box, and reboot your computer. You should be done with obnoxious prompts!
Jan 08, 2009 | Microsoft Windows Vista Home Premium with...
I keep getting this error message when I try and upload a page in DreamWeaver- or change an existing page. The pages are "locked" but I have never locked them and they have never been locked. I...
Try this:
To change permissions for a disk, folder, or file:
  1. Select the item you want to set permissions for, then choose File > Get Info and click Ownership & Permissions, if necessary. If you want to set permissions for multiple items at once, select them, and as you hold down the Control key choose File > Get Summary Info.
  2. Choose a permission for yourself from the pop-up menu. If the menu is dimmed, you don't have permission to change this setting.
  3. To change permissions for the owner, group, or others, click Detail. If necessary, click the lock icon and, when prompted, enter the name and password of an administrator user of your computer.
  4. Choose permissions for each type of user from the Access pop-up menus.
Nov 30, 2008 | Computers & Internet
Fatal error message
Hi all,
The error happens if your installation did not finish completely and you didnt have complete access and permission to the system(even though you are an administrator). Run the access denied tool by hp by clicking on the link http://tinyurl.com/5u2pg three times. uninstall the software and reinstall again. If this dosent work you will have to manually change the permissions in the registery.
hope this helps!
cheers
Aug 10, 2008 | HP Photosmart C4280 Aio Printer
jasbo
jasbo
