Question about Singer CE-100 Futura Computerized Sewing Machine
Wheel is stiff. Safety feature keeps stopping
Wheel is stiff. Safety feature keeps stopping machine. Machine is squeaky and smells hot. (Futura 100)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
Sounds like their is a bind, you will have to have your local dealer inspect it. Either the machine needs a full oiling or thread has wrapped around something inside.
hope that helps,
chris
Posted on Jun 06, 2010
How to deactivate the safety device on the Singer Futura SES 1000 embroidery machine? How can I get the hand wheel to turn again to get the machine to sew/embroider?
You can't--something is stopping the wheel from turning, and until you find out what is stopping it, your machine will be locked up. Take a look below the bobbin case, and you'll see a ***** holding a little door. It allows you to clean and see on the other side of the bobbin basket. Chances are, there's something like a broken off needle stopping the gear that turns the hook. It can also be caused by threads wrapped around the tension disks, or around the inside of the hand wheel itself. The hand wheel can be removed by removing the cap in the center--it is hiding a ***** that holds the wheel.
Feb 29, 2016 | Singer Sewing Machines
Safety Device Activates but no error message
It sounds like there may be something inside the machine. This happened to me twice. The first time was the wrong stabilizer. The second time I had a piece of thread inside the machine. When I opened it to see the thread was activating the error beep in the machine. I hope it helps.
Mar 10, 2014 | Singer CE-200 Quantum Futura Computerized...
My Futura machine sews and stops,sews and stops,whats is the problem?
check to make sure that the machine is plugged in to outlet correctly
and also plugged into the machine correctly
make sure the foot pedal is also plugged into the machine correctly
could also be a problem with the motherboard
or a problem with the foot pedal
if none of these suggestion help then the machine would have to
be checked
Dec 01, 2012 | Singer CE-100 Futura Computerized Sewing...
I purchased the Singer Futura CE-150. When I click on transmit to machine I do not get any response. I do not get the dialog box to pop up to allow me to sent to machine. I have uninstalled, I have check...
Check the sensor at the top of the machine. It is where the thread passes through the plastic "u-turn". Check to see if the wheel turns when you pull the thread through the machine. The wheel has a red marking on it. If the wheel isn't turning when you pull the thread, it may not be sensing the threading correctly.
I hope this helps
Mar 20, 2011 | Singer CE-100 Futura Computerized Sewing...
My futura ce-100 keeps beebing and it lights up. it stops working and will not move on. how do i fix this.
Check the threading, especially in the clear plastic tension race at the top back of the machine. This is the part where the machine checks the thread is moving. If the thread breaks, or is not running correctly through that area, the machine thinks the thread is broken/run out and stops.
Nov 16, 2010 | Singer CE-100 Futura Computerized Sewing...
How do you sew on the singer futura 250. I am
Pull out the embroidery unit. Raise the feed dogs. Change the feet. disconect from computer. It should be good to go.
Dec 13, 2009 | Singer CE-100 Futura Computerized Sewing...
Futura 100 Embroidery machine...Need to cancel previous transmit
Had the same problem. Singer rep. solved this mystery in just min. after talking to her.
You can call singer company at 1-800-4SINGER. It will take a long time to get through, but they can talk you thru to resolve this matter. Or just visit singerco.com and go to F&Q section, #7 question.
Or you can email talktous@singerco.com (that's talk to us @ ...)
They answered my email the same day!
Hope this helps!
Jun 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Ce-100
Go to www.futura-support.com , select "Futura machine" in the left hand menu, click on Instruction manuals, select your machine and download. Presto!
Dec 10, 2008 | Singer CE-100 Futura Computerized Sewing...
Whining also
ASAP....please it might just need service....how old is the machine?
Jan 20, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
291 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
