Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mower boggs down when blades are engaged
Runs fine till blades are engaged
    Problem Solver:
  • 18 Answers
If all pulleys are turning (not bound up) check for belt route misalignment.
Posted on Jun 06, 2010
Poulan pro engine dies when blades are engaged
Something may be wrapped around the blade shaft under the mower deck or maybe the shaft bearings are bad.
Aug 10, 2014 | Poulan Garden
Why does a craftsman tracor with a kohler 15.5 hp engine bogg down when engaging blades
It will initially bog down when engaging, but should pick back up shortly after. If it is staying bogged down, turn mower off and check inside (under) the deck to make sure its not clogged up with grass clippings or dirt. if it is, clean it with either a hose or a scraper. Also make sure the deck is raised when you engage (dont engage with deck lowered on long grass).
Jun 15, 2014 | Craftsman Garden
My john deere keeps shutting down when I try to engage the mower blades.
well first off be sure the throttle is all the way up secondly check to be sure the blads turn freely could be the belt is pinched or off one of the pullies and causeing to much friction for the motor to turn it
May 04, 2014 | John Deere Garden
Electric clutch troubleshooting
Possible fuel mixture problem, caused by contaminated or wrong fuel. Carby may need to be cleaned and fuel changed.
Mar 30, 2014 | Garden
Kohler 22 bogs down when i engage blades on zero turn, cleaned carb did not fix.?
Check the plugs, if they are black and soot covered you may have a float valve that is not sealing allowing a little extra fuel to get into the mix. If you have the savy to remove and clean the carburetor then you should be able to replace the float valve, one tiny spec is all it takes and the float overfills; if you clamp the fuel line shut and the tractor improves after using up fuel in the carburetor it is very likely an overfilled float bowl.
Sep 19, 2012 | Garden
17.5 briggs motor back fired 1 time and now when i engage blades the motor boggs down
The engine is timed internally and externally. Sometimes when it backfires the external timing key where the flywheel and crankshaft join will be damaged enought to put the engine out of time. The engine may run but when put under a load such as cutting grass it will fail. This is about a 30 minute repair and about $2.00 in parts.
Jul 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
Zts has no Power when Blades Engaged
check your blades to make sure that they are not hitting the deck,, this would cause the knocking sound
Aug 19, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
208 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
