Question about Kenmore 84072 Electric Dryer
Kenmore 84072 dryer runs doesn't heat - Kenmore 84072 Electric Dryer
  • Kenmore Master
  • 43,501 Answers
Hi, If you have a gas dryerKenmore 84072 dryer runs doesn't heat - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif iKenmore 84072 dryer runs doesn't heat - 2_bing.gif"http://www.fixya.com/support/t4734648-dlg5932w_not_drying_completely_hear_gas#">electric2_bing.gif..
There could be a number of different problKenmore 84072 dryer runs doesn't heat - 2_bing.gif/>Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 06, 2010
I have a kenmore dry that seems to hum very load once it heats up. If you turn it off and rest for 30 minutes it will sound fine again until it is 15 minutes into the cycle. What would be the likely...
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
GENE
Sep 12, 2011 | Kenmore 84072 Electric Dryer
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
Runs for little while then stops and has the code PAU on the display. I tried unplugging the cord, I reset the circuit breaker. Still the same and now it won't even start.
Try taking the control board out and check for burned off traces. Solder back those points and it should work again. Just did it to mine and now it runs again. Still flashes PAU though.
Jul 07, 2011 | Kenmore 84072 Electric Dryer
I had a power outage and now the dryer will not turn on. Is there some way to reset this. I have unplugged the dryer and still nothing
84072 is NOT a good model number.
Please post the correct model for a decent answer from the pros at FixYa.
May 20, 2011 | Kenmore 84072 Electric Dryer
The tube spins, but there is no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 15, 2010 | Kenmore 84072 Electric Dryer
Heating element is going out it work about ten percent of the time? need parts number and ways to get parts. and is it the actual heating element or something smaller electrical since it is intermitent ?
It may be your heating elements, but I would check your circuit breaker to make sure its putting out 110V on each phase as the heating elements are the only part in your dryer that use 220V, so if the circuit breaker is not outputing enough voltage that could be your problem (it's also a less labor intensive fix). NOTE: IF YOU ARE GOING TO REPLACE YOUR CIRCUIT BREAKER TURN OFF THE MAIN BREAKER TO HOUSE TO POWER DOWN THE BUSS BAR THAT THE BREAKER IS PLUGGED INTO.
Nov 03, 2009 | Kenmore 84072 Electric Dryer
Kenmore Model # 417.84072300 Dryer runs all programs when selected tumbles counts down but does not have any heat.
Thermostat controls heat. There is also a motor centrifulgal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Jul 06, 2009 | Kenmore 84072 Electric Dryer
Kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Dec 04, 2007 | Kenmore 84072 Electric Dryer
Error Code F2
That means the sensor that tells the computer what temp the drum (and the clothes) are so it can cycle the heater on or off according has failed. Please rate my help as solved if i answered your question! THANX
Oct 02, 2007 | Kenmore 84072 Electric Dryer
Kenmore 84072 Electric Dryer Logo
351 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
