Question about Park and Sun Sports PS-FAH Fold-A-Hoop Basketball Game
I don't have instructions for the park & sun fold a hoop and would like to know how high to hang the back plate from the ground.
  • J Mac Jun 07, 2010
    Thanks everyone. Finally got some instructions and it says the mounting plate is 7 feet high.
  • 821 Answers
Hello,you can kindly get your instructions manual from the link below and there you will find your steps and instructions,
http://www.tapthesun.com/PDF/WAZ-125%20Assembly%20Instructions.pdf
you can as well visit this site below for adequate instruction on how to set the park and sun fold.
wish you good luck,
take care.
take care.
Posted on Jun 07, 2010
    President:
  • 1,561 Answers
the hoop is ten feet tall from the floor to the rim of the basketball goal.
Take care.
Posted on Jun 06, 2010
    I was able to finally get some instructions. They say the top of the mounting plate will be 7 feet. Thanks for your help.
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Oct 10, 2016 | Volvo 850 Cars & Trucks
Can it be dangerous folding picnic tables?
You have tobe careful when you are folding picnic tables that you have followed all thesafety instructions:
  • Make sure the diagonal folding legs are lockedwhen in use
  • If you havefolded tables stacked on top of each other, don't pile them more than 10 tableshigh as they can fall
Jul 25, 2012 | Furniture
Can i use a plug adapter
don't use plug adaptor to any high amps electrical equipment
Jul 18, 2012 | Refrigerators
Tension problems
you need to find a different sewing machine repair shop
have you tried a new needle
have you tried changing thread--top & bobbin
clean under the needle plate & in the bobbin area for loose threads & lint
make sure every thread guide is used
make sure thread is not hanging up some where on the machine
when you have to take the machine in 3 time & it's no better, then their not fixing the machine, I highly recommend a different sewing shop to check out the machine if my suggestions don't help. no since in throwing money away, when their not going to fix the machine like their suppose to.
Mar 14, 2012 | Sewing Machines
Top worked fine yesterday but today tried to let down only clicked
It is a hydraulic pump that applies pressure to the 2 hydraulic pistons to raise & lower the top. So, check for something obstructing movement first.
The convertible top:
  • is motor-driven.
  • requires parking brake engaged to complete circuit for operation.
  • is equipped with a back window glass (42006) . The back window glass is permanently attached to the folding top back window curtain (52500) and cannot be opened.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged fluid reservoir.
  • Damaged folding top hydraulic cylinders .
  • Damaged folding top motor upper and lower hose .
  • Damaged convertible top regulator.
  • Parking brake not engaged.
  • Open power distribution box circuit breaker CONV TOP (30A), fuse junction panel Fuse 1 (15A).
  • Circuitry open/shorted.
  • Damaged convertible top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Convertible Top Does Not Raise/Lower
  • Open circuit breaker or fuse.
  • Damaged folding top switch.
Jun 29, 2011 | 1998 Ford Mustang
No lights on my license plate, bulb is replaced , no output on connectors . can you tell where are they connected so i can put new wires.
You need to follow the wires back to a connector
& do some testing for voltage and ground
I don't know why you talk about needing new wires,
they last the life of the vheicle 20 years or more.
Apr 21, 2011 | 2000 Dodge Durango
Replacment 7" basketballs
http://www.amazon.com/Voit-Voit%C2%AE-Super-Mini-Basketball-EA/dp/B001285TW8
One reviewer even specifically notes that he bought them for your same game.
Jan 04, 2009 | Park and Sun Sports PS-FAH Fold-A-Hoop...
Park and Sun Sports PS-FAH Fold-A-Hoop Basketball Game Logo
147 people viewed this question
Top Park and Sun Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Park and Sun Toy Expert? Answer questions, earn points and help others
