VCR tapes with large amounts of tape on them keep kicking off spontaneously
  • 6,993 Answers
its kicking off the tape because the large amount of tapes are stuck together and its not free in the player. The player cannot roll the tape because of this, so it kicks it off.
Get a tape rewinder, rewind and fast forward the tapes severally for the tape to be free/loosen so that the player will be able to role the tape.
Also you get hit the tape, this can also loosen the tape.
Good luck.
Posted on Jun 06, 2010
Sony slv-998hf has loose part
Look for a junker on eBay or similar. This reminds me, I have several machines I can sell for parts!
Nov 13, 2013 | Sony SLV-998HF VHS VCR
Vcr keeps kicking tape back out
Something is stopping the tape from fully loading.Do you have young children? Very often the kids will "post" something through the cassette flap. Remove the top cover & look inside the mechanism for any unusual object or its also possible something in the tape alignment path has broken which will also be lying inside.
Dec 25, 2012 | Orion VR213 VHS VCR
Ag-w1 mechanism
It may be a tape end sensor problem, kicks tapes back out.
Mar 25, 2012 | Panasonic AG-W1 VHS VCR
Emerson EWV403 VHS VCR stops taping and powers off spontaneously
There are probably a few different ailments which can cause this. One is if something is afoul in tape transport. I'd think the problem would occur whether in record or playback however.
If the tape takeup reel drive is slipping, tape takeup might intermittently stop, and cause the machine to power off (this is to avoid spilling tape in the machine). With the cover off, insert a tape, hit play, and see if tape takeup is steady, especially nearer the end of the tape, when the right reel is filling up.
An associated problem is if the reel sensor is intermittent- this sensor tells the logic whether or not the takeup reel is turning- again, this is to avoid massive tape spillage and damage.
Another possibility is a dirty mode switch- this switch tells the logic circuitry what position the mechanicals are in. It is probably located on the underneath side of the deck. Sometimes it can be disassembled and cleaned with a cotton swab wetted with contact cleaner. Others must be replaced.
Hopefully this helps- perhaps another tech has a better solution too.
Nov 12, 2008 | Emerson EWV403 VHS VCR
Excessive Dropouts
I had the same problem with my VCR. The problem is not a dirty head. I was connecting the VCR to the A/V input of those new TVs with the digital tuners. I got rid of the problem by connecting the coaxial (analog Channel 3 or 4) output of the VCR to the Antenna input of the TV and tune to plain old analog channel 3 or 4. That way you apparently avoid the digital circuits and those blasted dropouts; Now the VCR plays perfectly on my new 42-inch TV..
Feb 28, 2008 | Samsung SV5000W VHS VCR
Drawr problem with DAT deck
Tape transport is similar to VCR. Problem may be sensors needing to be re-soldered. Sometimes this will remedy erratic function
Feb 11, 2008 | Audio Players & Recorders
Vcr problem
this usually indicates an error condition- the logic is sensing an abnormal condition. Suggest taking the top cover off the VCR, and load the tape, then activate play. Does tape begin to spill out in the mechanisms, especially towards the right side of the tape? If so, then the take up spindle isn't being engaged to take up the tape. This at least was, a common problem with VCRs, especially older ones ('80s era) which used a rubber drive wheel. This rubber "tire" like drive would become slick & hard, and would cause a no-takeup condition, spiling tape out. There was a sensor which told the logic circuit if the takeup wheel was indeed turning, and if not, the VCR would be taken into a stop or shutoff mode. This sensing would prevent large amounts of tape spillage and the resultant damage such would do. Another possible cause is the tape isn't being loaded properly. This is generally due to a defect in the carriage mechanism (the assembly which holds the tape). Often, these mechanisms were gear driven. Timing on these gears is often critical, and being off by just one tooth would cause an error.
Sep 17, 2007 | Symphonic SL260A S-VHS VCR
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Commercial Advance feature shuts off vcr.
You need to clean the video tape path my freind, or the machine needs an alighnment. you can try to clean it with a head cleaner, and it might work, but most of the time you need to have it professionall cleaned. If you want open this http://www.bealecorner.com/trv900/trouble/cleaning.html, and it is about the same proceedture with a camcorder to clean a VCR, just take off the top cover of the VCR. Good Luck Please do not forget to rate this thread.
Nov 27, 2006 | RCA VR555 VCR
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
