Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
It is leaking from the bottom where the electrical cord goes into the unit
    Scholar:
  • 106 Answers
Sounds like a seal is blown...have to replace the unit all together
Posted on Jun 15, 2010
Garbage disposer leaking at bottom
Since you have checked all pipes and see no leaks next please check the area around the top and bottom of drain housing. If that's not leaking there is a gasket inside the disposal that could fail and cause water to leak into the motor area and then leak through the bottom of the unit. Generally in my experience replacing the whole unit is a time saver because access to that gasket is a pain and finding the right gasket can be timely. Depending on how old the unit is I would just replace it.
Jul 06, 2017 | Electrical Supplies
My dogs chewed and ripped out the electrical cord to my haier 10000btu a/c unit, model# hwr10x1c. I know where the the green ground goes, but where do the Other 2 go?
A 10,000 BTU A/C is probably a 110 volt unit. You are correct that the green wire goes to the ground terminal of the plug. The red or black wire is the "Hot" wire and would go to the "narrow" prong or "right" side of the receptacle - when the ground is on the bottom (if it is installed correctly) as you look at it. The white wire goes to the wide prong or left side of the receptacle. If the plug is fine and you have to connect the wires to the unit, there should be a wiring diagram to follow inside or on an electrical cover plate. Polarity is critical, so be sure what you do or let an electrician do it for you. Good Luck!
Mar 30, 2017 | Heating & Cooling
F21 code displayed> cleaned water trap next to water pump that had lots of stuff plugging the filter but now power cord GFCI plug shuts off when I try to Start washer...
Hi you could have a clogged drain pump or obstruction in it. Remove the lower bottom cover. Have a container or towels to catch water. Removed the drain cover by turning counter clock wise. Sometimes you have to remove the pump to fully and clean. You also need to plug the washer into another outlet. If possible use an extension cord use the extension for test only.
Apr 25, 2014 | Whirlpool Duet WFW9550 Front Load Washer...
No power to dishwasher, but power is there
digital readout? How do you know power is there? power lines usually picks up near front of the unit. Remove bottom grill and take a look or should pull out easily from the countertop. Be careful but get electrical tester and make sure power goes beyond the cord.
Nov 09, 2013 | KitchenAid 24 in. KUDI01FLSS Stainless...
How does the bottom plate come off a badger garbage disposal
Hi, the only plate that should be removed on the bottom is for wiring the power cord to the unit. If there is water leaking, specifically from the bottom of the unit, it's leaking through the enClosure assembly which is not serviceable. If the unit isn't that old it might just be leaking from the sink flange or mounting gasket at the top of the unit which at times can be difficult to detect. Or possibly the gaskets at the drain assembly for the unit. Hope this helps ;)
Feb 01, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Replacing electrical cord
if you buy a color coded cord and plug then red and black go on thee 2 outer terminals of the power terminal and the white wire goes between these as this is the neutral connection and if it has a green ground wire connect this anywhere to the metal case of the unit, if its a gray cord with no colors then the 2 outer wire on the cord go to the outer terminals on the units power terminal block and the center wire on this cord goes to the center terminal on the unit
Jul 28, 2012 | Roper REX4634KQ Electric Dryer
The electric cord plastic jacket melted and burned through wire on one spot. Can the cord be replaced
I am currently attempting to do that myself. You need to separate the liner from the outside part. Using a pair of pliers, loosen the round nuts (found on the bottom) holding the unit together & separate. You'll find that the unit won't come completely apart because of the wiring. There is a heating band, held together by a spring, around the inner liner. Remove the spring to release the band. This should allow you to remove the inner liner & give you access to the wiring. At this point, you'll need to clip the appliance cord by the little wire nuts. The hardest part will be getting the cord out; there is a strain relief grommet that holds the cord in place and prevents it from being cut by the sheet metal where the cord goes through. I broke this strain relief on my crockpot and am currently looking for a replacement. Once I find a cord relief, I should be able to reconnect the wiring, the heating band and assemble the unit. Be careful not to cut yourself on the sheet metal!
Nov 23, 2011 | GE 106661 4.5-Quart
I have a Whirlpool ET8GTMXK000. The refrigerator was hit accidently on the side, and it quit working. On the very bottom corner on the left back side there is a black spot where it looks as if an...
You are correct, it sounds like an electrical short happened. I am guessing when it was hit, it caused the cord to get pinched in the metal casing. The pinching must have broken the insulation on the cord and the casing is grounded...therefore, instant short. The unit probably wasn't hurt but will need to have a new cord. If you follow the now unplugged cord to the refrigerators electrical connection, it is probably either held on by crimped connectors. Cut those connectors off as close to the connectors as you can (on the opposite side of the power cord). Follow the path of the old cord and remove it from the unit. A new cord can be obtained from a local appliance store or ordered online from places like applianceparts.com. Put the new cord back in the same path the old cord was removed from. Make sure there is no sharp metal to puncture the new cord where the old cord was pinched.
Hope this helps
Jan 21, 2011 | Refrigerators
Badger 5 leaking out bottom where the electrical cord is
Unfortunately, this generally mean the shaft is bent or the seal is damaged. The way these unit are designed they're not repairable.
The only good new is that if you stick with the same basic unit you can replace it in about an hour and you won't have to make any major changes to the plumbing or electric. If you have dish washer be sure to knock the plug out of the opening for it hose.
Jun 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Toshiba Satellite P105 S6124 Power goes off. Jiggling electrical cord at base of computer gets it back on but when it's moved, it goes off again. Someone looked at it and tried a new cord. Determined...
First, the power cord connects to the Power Unit not the Motherboard, so if jiggling the wire causes the fault, it is either the Power Supply Unit or just the plug and wiring that the power cord plugs into.
If you must open the casing, try replacing the Power Unit, but the best solution is to get a computer repair person to look at it.
If you pull the unit apart and start poking around in there, you will almost certainly blow something up with static electricity (and then maybe your Motherboard will need replacing!). Note The voltage of Static Electricity (which you probably can't feel) is THOUSANDS of times higher than the Voltage that your computer components runs on. For comparison connect up a Mains Supply to a 12 volt globe and see what happens (and this is only 10-20 time higher than the required voltage.
Good luck.
Apr 13, 2008 | Computers & Internet
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
149 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
