Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
I cannot find the model number of our Hoshezaki icemaker. It is free standing, about 18 by 36", the water flows over the plate and recirculates until it is all frozen. The ice is thinner than it is supposed be. It does not make enough ice.
  • 8,220 Answers
You can increase ice production by simply cleaning the dust off the condenser.
Posted on Jun 06, 2010
How can I find a wirning diagram for a ice maker that has guit making ice but the pump will run?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Your Ice machine does not have a wiring diagram. I have repaired many of these.
1.) Are you getting water? If not it is your pump.
2.) Reach in and feel the cold plate. Is it cold? If not you have a refrigerant leak.
3.) The problem may also be within your main control board.
Unless you have a current service contract these units are considered throw-always. It will cost you twice as much, if not more, to repair it than what you purchased it for, assuming you call a service company.
Go into the following website. Plug in the first 5 numbers on your model number and a list of model numbers will appear. Your model number is incorrect.
Select the model number then click on parts and you will get diagrams of your icemaker. Water Filters Lawn Garden Appliance Parts
Mar 21, 2015 | KitchenAid 18" Ice Maker - Black
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
Ice Makers
It should have a regulating valve to help control the head pressure. It is adjustable to maintain a constant head pressure. The higher the pressure, the more the water should flow to keep the pressure down. Since there is not model number, I can not suggest an exact setting.
Sep 06, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Sears Kenmore free standing ice maker not making ice
Hi and wel;come to FixYa. I am Kelly.
Do you know if the compressor is even running?
Also how long has this icemaker been in service?
There are only 3 things that can cause a condition that the unit is not freezing.
1. Low coolant
2. The compressor is not running.
3. The condensor or evaporator fan is not running.
Having said that...
The most common failures for a cooling system are
the PTC relay / thermal overload and the run capacitor.
PTC Relay is item 18 of link below
Thermal overload is item 20 of link below
The condensor fan motor is Item 4 of the link below
Link:
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0109006-00005.png
Item 5 the electronic control board (see link below) controls the operation of the compressor via the thermostat Item 12 of link below. In addition to that there is also 1 thermistor (Item 20) that is also part of the control circuit.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0109006-00004.png
ANY of the above can cause your icemaker not to function correctly. It will take circuit analysis to isolate which component may be causing your current system.
If the compressor is running and it is not cooling then
There can be any one of the following causing the problem.
1. Low coolant
2. A stuck valve for the cooling / ice making system (5ea)
3. The compressor can be running but not up to speed due to a dragging rotor.
I wish I could say _______ part is what causing your current symptom. It just is not possible without someone doing some on site troubleshooting of everything listed in this post.
Kelly
Link to all of your units parts:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=106.89482993+&=part+number&pathTaken=partSearch
Apr 17, 2010 | Freezers
No water flowing to ice maker
to see if icemaker is still good pour a 1/2 cup of water into tray and wait for a day. make sure shutoff arm or switch is on or down (arm down) if it makes ice then the icemaker is ok. if it dont then hold up.
if it makes ice then either the water pressure is too low (or no water) or the water valve is bad. (to check water valve you need a volt meter).
ok back to hold up part... the icemaker actuallys controls the water valve so you can have no water but that doesnt mean the icemaker is bad. so here are the three possiblities to your problem:
ice maker
water vavle
not enough/no water
before you buy anything let me know and we can go over this again
hope this was helpful (or confusing sorry)
Apr 02, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Kenmore icemaker won't work
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Oct 26, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
123 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
